Question about Garden
No spark john deere 777
Both cylinders not firing
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
  • 9 Answers
SOURCE: john deere mod 345 no spark
first find the wire that is grounded to mower to ignition
and check that it is isolated if mounted on some plastic and disconnect it
if it runs to start switch check wire for cuts also
most common problem is the coil located under the top plate held on by 4 /5 screws on sides.
remove top and follow plug wire back to coil
you can clean the curved edges of coil that are against motor {magneto} with sand paper and clean mag
remove plug and lay threads securely agains frame and check for spark {hold by wedging not by hand as you can get a jolt!}
Posted on Aug 20, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
  • 13 Answers
SOURCE: john deere lane rider la135 wont start.
You don't mention if they are on and are bright or are week. Do they dim when trying to cranks the motor? I would start with checking the ground wire at the battery and where it connects to the frame. Make sure both are clean. From there, have the battery tested and then the starter.
Posted on Jun 10, 2010
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
Need a belt diagram for all belts for john deere ztrack 777 mower can't find belt diagram for belt from deck to motor
Its on google just found it just put in john deere 777 mower belt track it shows how it goes once you see it its simple to install , you may find it on u tube . I changed my belt bit of a hair pull but once you see it .Its easy .
Nov 03, 2016 | John Deere Garden
My john Deere turns over but want start
If it's a single cylinder engine, my first guess is the magneto is defective. Other possibilities are defective spark plug or spark plug wire (from magneto to plug). Verify also that the fuse is good.
Jun 17, 2015 | John Deere Garden
What is my problem with my mower oil too full and has gas in it.
Your rings on your piston cylinder provide a seal between the piston and the cylinder wall. If the rings leak, gas from the cylinder can leak into the crankcase. Plus you will lose compression. May need to take it in and have a pro look at it.
Jul 19, 2014 | John Deere Garden
I have a john deere 737 mower and it started running on one cylinder. I bought a coil for it and put it on and had the same problem. so I looked into it a little more. I am not getting any spark at all if...
You have the wiring hooked up wrong. The way you have it is grounding out the coil that isn't working. I have ran into this problem at our shop only once. Only after contacting tech support was I able to get it right. Unfortunately I cant for the sake of me remember how I did it. I do remember that when I got it right, it didn't look like it would work. I am frustrated at my self for not being able to remember.
Oct 30, 2013 | John Deere Garden
John deere 737 mower
I had this kind of problem on my cub cadet. it was a weak coil. Replaced the coil and all was good.
John deere not firing
Did you set the gap between coil and fly wheel Are you sure that's the problem No spark can be caused by lots of things from a switch
Jun 21, 2013 | Garden
I have a john deere stx38 and it has no spark and wont fire but engine turns over
Check the shear pin in the flywheel, replace if bad, should cure your no spark problem
May 28, 2011 | John Deere Pto Clutch For Stx38 And Stx46...
John deere lx 178 1 cylinder firing
pull plug if its wet you have a firing problem if not the you have a fuel problem! been my expierence use only jd parts on that bad boy! little more $ save you several little head aches!
May 26, 2009 | Garden
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
