Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Where is high temp sesor - Dream Maker Spas Dream Maker Ez Spa Hot Tub
Radiator fans not working
temp sesor in the engine failed need new one 60.00 to install 80.00
Oct 03, 2014 | Cars & Trucks
Hydropool hot tub
defective temp sensor or heating element temp sesors usually ohm out at 78 ohms
Sep 16, 2013 | Pool & Spa
In 3100 engine temp guage peak out right after starting car ,changed temp sensor ,thermostat ,water pump and radiator .rpm still peak out and rpm goes up to 4000 rpm whats wrong
Sometimes even a new sesor can be bad. It does not happen often but it does. If not it could be a short. Make sure you do not have a bare wire grounding out. As far as a high iddle it could be your TPS. Just a place to start good luck.
Aug 20, 2013 | Cars & Trucks
What control the fuel delivered to injectors?
The ECC sends a signal to the injectors. Based on other engine conditions.
Fuel pressure, temperature and other sensors.
Jun 30, 2011 | 2001 Hyundai Sonata
Light and fan will not turn on.
the temp sesor may be defective. check fuse or relay
Sep 19, 2009 | NEC MultiSync VT45 Multimedia Projector
High idle when warmed up 2000 toyota corolla
may have vacume leak .unpluging map sensor will set a code light.
Jan 01, 2009 | 2000 Toyota Corolla
Dodge raider 1989
then the temp sesor is gone a wire coming out of a plug on tranny usually single/double wire
Dec 03, 2008 | 2005 Lincoln Town Car
Temp sensor
Bypassing the temp sensor may cause a FIRE!!! I don't recommend this.
Aug 14, 2008 | Samsung DLP HL-P5663W 56" TV
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
66 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
