Question about Blenders
Why is my ninja blender not spinning ? I've had it for a while an used it many times how can I fix it?
    New Friend:
  • 51 Answers
Sounds like the gear is stripped inside
Posted on Apr 25, 2013
  • 1 more comment
  • evan Apr 25, 2013
    How can I fix it?
  • Marina Martin
    Marina Martin Apr 12, 2014
    i have the same problem, tried to blend a spoon (accidentally)...
  • If you are mechanically advanced take the unit apart and look at the gears inside I suspect one is broken
    New Friend:
Fartz made out of p0Op
Posted on May 17, 2016
It's the nylon gear that is stripped.I have the smaller QB 950 30.Both the nylon gear in the main housing and the blade are stripped.I am looking to replace the nylon gear and blade.Not sure where to get the parts.The gear is held in by a screw so it should be easily replaced.Should have been made out of metal.
Posted on Apr 05, 2015
Mine is doing the same thing. It is NOT the blade shaft, it's the gear drive INSIDE the motor housing. I'm currently trying to figure out if I can put metal gears inside the housing instead of the plastic ones........POS for sure!! Never getting another Ninja blender!!
Posted on Dec 31, 2014
3 Suggested Answers
odiebugs
  • 949 Answers
SOURCE: Blades on ninja blender won't spin, but motor seems to be working.
I don't have one, but inspect the shaft, it looks like there is a key on the shaft, then inspect the inside of the blade where it goes on top of the shaft, see if it looks like the shaft has spun out the blade and this is why it's not spinning.
Remove the blade and the container, then turn on and see if the shaft is spinning, it should be most are a direct drive.
So now if the shaft is spinning, that most likely means that the blade hole is broke where it sets on top of the shaft.
Look closely at the inside of the blade, you should see some type of damage like the groves are worn, I hate to see you buy one and it was the shaft that wore, but usually the blade will go first.
Posted on Mar 31, 2013
SOURCE: Ninja blender second time
Put the lid on so the arrows meet up. There is a arrow on the lid and handle put them to gather and blend!
Posted on Mar 05, 2012
Why won't the blender start? the on/off light keeps blinking
my Ninja blender wont turn on, power button keeps blinking red ...
https://answers.yahoo.com/question/index?qid...
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Ninja Blender Red Light Is Flashing ' Appliance Repair ...
appliancerepairquestions.com/question/ninja-blender-red-light-is-flashing/
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
www.fixya.com > Forum > Tags
Dec 26, 2015 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Not working
How to Fix a Blender ' DoItYourself.com
www.doityourself.com/stry/how-to-fix-a-blender
A food blender is a far less complex machine than most people might imagine. Because of this simplicity, you can easily determine the cause of a non-working ...
The Ninja Ultima Blender: What To Do When Power Light Is ...
? 0:36
https://www.youtube.com/watch?v=LfY_-VA5m8A
Oct 16, 2013 - Uploaded by Ninja Kitchen
... Blender start flashing. If the light on your Ninja Ultima Blenderis flashing, check the following... ... Still not working. Read more Show less.
Dec 09, 2015 | Blenders
Ninja blender 1100single server sticks after using hard to loosen
I experienced the blades freezing on a different blender after making smoothies and letting the unit sit for some time. The problem was sugar seeping into bearing interface and solidifying. I soaked the blade assembly in water and they freed up.
I now add water to blender container after each use and operate it until clear water seeps out the bottom of the bearing.
Oct 24, 2014 | NINJA Kitchen System 1100 - As Seen On...
Where do I find lids for the nj600 blender
Ninja Professional Blender . if this link works it will show the lid for the blender. If the link does not work, do a web search " Parts and accessories-Ninja. On the top menu, click on parts and scroll down to Ninja professional blender nj600 and click on it.
Jun 06, 2014 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
Power light is blinking and the blender will not work
Align the arrows on lid and handle, and latch it down before you put the pitcher on the base and spinning it to lock it in.
Mar 18, 2014 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Ninja Blender 1100 starts then stops almost immediately, is there a way to fix this?
It Could Be a Number of Things..
It's most likely that the electrical Wire Could Have a Shortage, If it cuts off again Try gently Wiggling the Electrical Wire in a Number of Directions If it cuts on and off while your fidgeting with it, you've found your Problem! A quick fix would be to Adjust the wire In the position it would cut on the strongest, wrap the cord with Tape to Keep the wire in that Position, this will Prevent it from shorting again.
Either that or you simply put too much product in the Blender with an inadequate amount of liquid.
Jan 04, 2014 | Blenders
Mar 31, 2013 | Blenders
Ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Aug 18, 2012 | Blenders
My ninja blender motor starts but the blades don't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Jun 18, 2012 | Blenders
Blenders Logo
3,155 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
