Question about Coffee Makers & Espresso Machines
The machine is beeping, and I can't seem to find out why. I've cleaned it. The problems use to show at the screen. It's a cimbali m1program. It shows a little 'snowflake' as well. I'm lost.
    Master:
  • 435 Answers
I hope this helps
Posted on Apr 23, 2013
  • annakimsloth Apr 25, 2013
    Thanks. We ended up having a technician to look at it, 3 times yesterday. But it was an error55, something about a heater.. I don't know!! Thanks anyway
3 Suggested Answers
  • 219 Answers
SOURCE: can I get an instruction booklet showing me how to
Check one of my other posts where I give the step by step function.
Posted on Jul 30, 2011
  • 115 Answers
SOURCE: Sir, LA CIMBALI 39 DOASTAROM 3 GROUP MACHINE
hi. Im not sure excactly what is going on with your explaination about your machine, but I gather the the original mother board has died, and you have replaced it with a new one. It sounds like you have a water fill issue with your machine. If the boiler doesn't have enough water in it, then the pc board will shut the machine down. Ive never worked on a m39, but they are from the Faema corporation, and Faema/ La Cimbali electronics canbe very complicated. Dont now why they make such complicated electrics, cause there are hundreds of other brands with simple electrics.
If your boiler was empty, then the water fill cycle might be a timed cycle, and is shuting down before the water level has reached the water level probe inside the boiler. If this is the case, then once it has stopped, turn the machine off, wait 10sec, then turn it back on again and let it start the fill cycle over. You may have to repeat this a number of times until it has reached the water level probe inside the boiler. Some machines are designed to have a slow water fill, because when you draw hot water from the boiler for making tea, fresh cold water is pumped back into the boiler to replace what you have taken out, and if it fills too quick, then your steam pressure drops. So by filling slower, the machine will maintain its steam pressure. Good idea in theroy, but its only good for cafes that do 300 coffees per hour.
Im hoping that your machine is configered this way, cause it will probably just have to be turned on a few times until it has reached the water level probe as I explined in the begining. If you have a sight glass, you can check to see how high your water level is. If your level is correct, and its still not working right, then id recomend calling a repairer. There are number of things that could be wrong, causing your board to die. Faulty solenoids. switches, touch pads, pressure switches can cause main board issues. Hope all this helps with getting your machine working properly. Dazza Repairer
Posted on Oct 23, 2011
What's carry out maitenance mean its showing on my
M2 supper automatic have a programmable maintenance schedule set up by the technician whom installed the machine (if this is the original location.) Call your vendor as it must be reset and cleared by a certified technician. The machine will lock out if not cleared. Some machine s will continue to be operational but needs to be reset every morning after bypassing error. Naturally continued use of machine will eventually fail from a more serious problem as errors are ignored.
Sep 13, 2014 | Coffee Makers & Espresso Machines
Cimbali m1 locked out
Machine might have calling for a clean cycle for a while, if it does not get one it lock up until cleaned.
Sep 30, 2013 | Espresso RMI La Cimbali Espresso Machine
My PS 3 comes on but no display on the TV. I've
Stupid question i know ,buut, have you pressed AV on your TV remote !!
Jul 16, 2012 | Sony Playstation 3 (PS3) Console
La Cimbali Espresso Machine: How do you calibrate the dosing for a Cimbali M29 ...
Press and hold any Group stop button until beeping, then all the button will copy what you press. Hit any stop button to leave program.
May 18, 2010 | Espresso RMI La Cimbali Espresso Machine
Hi, I have an old model la cimbali p/tre espresso machine. It has connections for gas but I,ve no idea how to set it up, any ideas anyone??
When it comes to gas connections on the espresso machiones I will usually tell my clients to take it to their heating(furnace) expert, because if it is set wrong you can burn down your place.
Jun 09, 2009 | Espresso RMI La Cimbali Espresso Machine
My barsystem m2 machine shows that it needs to be serviced.
Check out this site it will give you a list of all the dealers.
http://www.cimbali.it/eng/contatti_network.asp
Apr 22, 2009 | Espresso RMI La Cimbali Espresso Machine
Cimbali M29 Select
Remove the 3 screws on the side of the bell they might be bolts or allen wrench screws. That will give you easier access to the screen and screw(make sure you have extra screen and screws).
Aug 18, 2008 | Espresso RMI La Cimbali Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
