Question about PerfectAire 50-Pint Electric Dehumidifier - -
MY PERFECT AIRE 50 PINT DEHUMIDIFIER HAS STARTED TO FREEZE UP
Tip
My Comfort-Aire BHD 651-C died
The Comfort-Aire crapped out again! We started the season with a little 17-pint Sears, but it wasn't cutting the mustard getting the accumulated moisture out of the cellar, so we fired up the Comfort-Aire 65-pint machine. It got the humidity down to 50% pronto, and kept it there for the better part of a week when all of a sudden it quit. Died! Nothing! Not a glimmer in the control panel, and pushing the buttons did absolutely nothing. Unplugging it and plugging it in again produced a faint "chirp" but that was all. Naturally, the thing is weeks out of warranty. Without the warranty, the nearest service place wants a $60 "consultation fee" just to look at it, so I decided to see if I could fix it myself before seeking professional aid.
After getting an exploaded view of the machine from the web, I removed the collection bucket, the filter, and the two screws from under the plastic front cover. In addition to the two screws, the cover is held by little tabs that fit into notches in the steel sides. To get the plastic cover off, I slid a wooden popsicle stick under the plastic, thus stretching the plastic enough to get the tabs out of their holes without scratchng the unit.
The front cover is tethered to the unit by a cable attached to a circuit board which forms the back of the push-button control panel. On one side of this circuit board there is a row of 14 soldered connections. They are very close together, and any conductive contaminent that gathers between them is guaranteed to short them out. That's apparently what happened to mine, for scraping between them with a toothpick, and cleaning them with a toothbrush
brought the unit back to life again. That's all it took to repair my Comfort-Aire. The plastic cover snaps back
in place easily.
on Jun 09, 2008 | Comfort-Aire BHD-651 Dehumidifier
Why do the coils freeze on my zenith zd309 dehumidifier
Coils can freeze if the room is extremely hot. Usually, though they freeze because the path for air flow is reduced. Check input and output grilles and coils for dirt and dust and clean as necessary.
Aug 02, 2014 | Zenith zd309 30 pint dehumidifier auto...
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
How to set timer on 2014 Kenmore 50 pt Dehumidifier
if you hold mode button down does it not cycle thru timer settings?
May 24, 2014 | Kenmore 30-Pint EnergyStar Dehumidifier
Need owner's manual for Perfect Aire 30 pint Dehumidifier Model PA 30
I found the manual available online at: www.perfectaire.us/PA30_Manual.pdf
Apr 01, 2012 | Dehumidifiers
Golstar dehumidifer
Either you are under sized. or it is over heating. 50 pint should be used in 1000sqft area. it maybe over heating or the vents maybe plugged one of these is your problem.
Jan 07, 2010 | Goldstar DH504EL Dehumidifier
I need a manual for a 50 pint DeLonghi dehumidifier
delonghiusa.com has a manual for a DE500P this may be close enough to yours
Aug 28, 2009 | DeLonghi DE500 50 pint Dehumidifier...
I have a Kenmore 50 pint dehumidifier Model 580.54501400
It looks like it is simple to get the filter out but we are finding it to be imposible. How can we take it out. It doesn't just pull down.
Jul 09, 2009 | Kenmore Dehumidifiers
What is the proper humidity control % setting?
It is recommended that your settings stay at 35%. The ideal level of humidity in your house is anywhere between 30% to 60% depending on the weather outside.. I hope that this works for you. Have a good day
Feb 09, 2009 | Kenmore 54701 Dehumidifier
PerfectAire 50-Pint Electric Dehumidifier - - Logo
60 people viewed this question
Top PerfectAire Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a PerfectAire Dehumidifier Expert? Answer questions, earn points and help others
