Question about 10 10 Computer Millennium G200 (8 MB) Graphic Card
Online Gameplay Problems
I try to Play RYL2 Incomplete Union. Every time I try to play my game crashes with multiple error messages such as resolution errors sound fails etc.. I have no other problems with the computer just this game. I have ASUS P5GD1 PRO Motherboard, Radeon X700 Videocard, Gig of Ram and Pentium 3.2G I have 2 comps hooked upto a router and ADSL connection. The Other computer is more Basic but has no problems with the game. I have tried setting Videocard to performance, updating drivers with no sucess. Please can you help a game addict back to his addiction? Thank you Paul
  • 29 Answers
Re: Online Gameplay Problems
Not sure but in the past when I have had graphics probs sometimes I've had to reduCe the resolusion, in other word dont have the settings so high. Other option is as other has said, different graphics card. The monitor if CRT may not have the resolution and a TFT more suited. you didn't say what monitor you are using?.
Hope you get sorted.
Posted on Feb 15, 2008
  • 71 Answers
Your grafics card is clashing with some thing the best theing will bbe to change your grafics card with the more basic one if you dont want to do this contact me
Posted on Aug 12, 2007
0 characters
3 Points
PNY GeForce GT440 crashes every time I play a video game.
Hello try to renew the graphic driver from here:
By selecting the model, and your windows system.
You can also use the auto find function.
By installing a small bit of software.
Maybe your power supply is too small for gaming performance
consider to upgrade that, if the driver update does not work.
I suggest a 500 watt PSU, so the graphic does not runs out of power.
Good luck
Feb 22, 2013 | PNY GeForce GT440 1024MB PCIe
Whenever I run a game on my laptop it freezes after about 30 minutes of gameplay. When I play in window mode I can see the following error message pop-up:...
yep you have a overheating problen card could be pulling to much power for your system. the only thing I can suggest is that you use the lowers graphic setting  these take less power to run or get a different card with a lower power rating
Feb 05, 2010 | ASUS RADEON HD3450, AGP Video Card
My PC gets stuck...
This could be a problem with the game's memory allocation. Try installing the latest patch for the game. You can find the patch in the official website of the game. Also try reducing the graphics quality by turning off anti aliasing.
Mar 27, 2009 | XFX GeForce FX 5200, Graphic Card
ATI Rage mobility graphics card update for dualview
Display Driver 13.3MB 8.12 12/10/2008 Display Driver Only tooltip.gif try this you might need new update to receive dual view
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI
Catalyst™ Software Suite for Windows XP. These include:
• Using an HDMI cable to connect an ATI All-in-Wonder to a Yamaha receiver
may result in the display resolution being limited to 1280x1024 and audio
failing to function
• Catalyst Control Center, some of the 3D settings are not displayed on ATI
Radeon HD 4870 adapters
• The operating system may fail to start after installing the display driver with
some configurations of "Crosfire" with Radeon X1900 Series devices
• The operating system may intermittently fail when exiting Test Drive Unlimited
after extensive game play
• Dual display, playing multiple video files on each monitor may cause the system
to stop responding
• City of Villains: Attempting to launch the game on a system running Windows
XP and containing either two ATI Radeon HD 38x0 or 46x0 products
may result in the game failing to load and the operating system failing to
• Some OpenGL applications may cause the OS to stop responding on some
ATI Radeon HD 45xx adapters
• On some configurations, the display driver may stop responding when resolution
is set to 2048x1536 with 8X Anti-Alias and Edge Detect filter enabled
• Exiting some games may intermittently cause the following error message
when 8X anti-alias edge detection is enabled: "Display Driver stopped working"
• Hot unplugging a HDMI connection during video playback may cause system
• Catalyst Control Center: Enabling pulldown setting may not work on all video
• Systems configured with Overlay Theater Mode enabled may intermittently
become unresponsive after playing video
• Catalyst Control Center, setting the de-noise slider does not affect the quality
of progressive video content
• Intermittent flickering may be noticed on the TV out display when playing a
DVD using Cyberlink PowerDVD
Jan 22, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Ati2mtag causing crash - ATI vid card
This error normally occurs if the card becomes unstable due to overclocking, heat or is faulty. The fact that the more you play the more it crashes lends credence to this being an overheating issue with the gpu. The options to resolve this are to make sure the gpu fan is functioning probably on the graphics boards and replace if necessary. While doing that I would look at the cooling setup for the entire system to make sure their are adaquate front, rear and if possible side fans to circulate air properly. Obviously the more a gpu overheats the more it's life cycle is shortened. You may want to take the second option of replacing the card.
May 02, 2008 | Graphics Cards
Unable to play the PC game Crysis
AlanChong20, update you're video casr software. The radeon 9200 last update is listed at this link.
The date for the upgrade is Nov. 15, 2006 No more driver update are being made.
If you're game still gives you the same error try lowering the game graphics detail settings. If set to high, bring them down to medium. It very possible you're card does not have enough memory to play the game. The 9200 is a older card. It may be time to upgrade.
Apr 13, 2008 | Graphics Cards
Laptop crashes every time I play a video game
Have you made 100% certain that you have the right driver. The laptop versions of nVidia cards are different to their desktop counterparts.
They use the suffix of "go" and the drivers normally have to be obtained from the laptops website.
Apr 12, 2008 | Quicksilver , Mac ATI RADEON 7000 64MB...
Graphics Cards Logo
107 people viewed this question
Top 10 10 Computer Graphics Cards Experts
phoenix chi
phoenix chi
Are you a 10 10 Computer Graphics Card Expert? Answer questions, earn points and help others
