Question about Kubota Garden
Lift arms on kubota box 1500 won't lower to connect mower
Can't connect mower as hydraulics are not working to raise and lower mower.
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
SOURCE: hydraulic lift pump not lifting how to replace pump
I have a Ford 1700 and the first time this happened I assumed it needed the oil changed (DID NOT read the manual). After changing the hydraulic oil for about $50... it ran no better. Read the manual. Bought the hidden oil filter. Bought new oil. Problem solved. The filter on this tractor sits in the bottom of the rear end housing and collect ever piece of junk. Good! But a pain to change the filter.
Posted on Nov 24, 2009
  • 251 Answers
SOURCE: ALLIS CHALMERS 190 GAS -HYDRAULICS ON TRACTOR ARE
hi , replace your hydraulic oil filter and pump and renew the oil .
hope this helps
Posted on Jun 21, 2010
  • 135 Answers
SOURCE: The hydraulic pump does not shut off and the lift
Sounds like you have a hydraulic flow valve problem. Check the lift arms when the pump is running to see if you have any hydraulic fluid leaking there.
Posted on Nov 18, 2010
SOURCE: I have a lawn mower
Larry,
I have a Troy built x20 lawn tractor and the lift cylinder moves until the weight of the blade is on it and then it stops. Sounds like we have the same problem. Any luck with yours? ANy answers out there. Again, the cylinder will move raise and lower until the weight of the blade is applied. The left to right cylinder will move but very slowly. Any ideas from anyone would be appreciated.
Tim
Posted on Feb 07, 2011
Loader stuck in down position, the joy stick will not raise or lower loader. The joy stick will work the tilt movme
didnt specify type of machine( generic answer)some machines have an electrical assist joy stick check switchs if hydraulic check the r check fluid level in the hydraulics the tilt uses less fluid to the piston than the lift arms ----check the hydro lines and connections doesnt happen all the time but try bleeding lift lines air or debris in lines
Sep 15, 2015 | Cars & Trucks
Need to replace main drive belt for sickle bar
Instructions
Put on your work gloves. Check the frame size for your mower. It will either be a 56-inch frame mower or a 76-inch frame mower. When you have determined the frame size, adjust the tractor's rear wheels to the mower's frame size. For 56-inch frames, adjust the rear tractor wheels to 56-inch centers or less. The same rule applies for 76-inch frames.
Back the tractor into a position where you can align its left lower link to the mower's lift link pin. Attach these two parts together and secure the connection with the tractor linchpin.
Roll the tractor and adjust the leveling crank until the tractor's right lower link can be attached to the right link pin on the mower. Use the tractor linch pin to secure the connection.
Attach the upper link from the mower to the lower hole in the tractor rocker arm by using the link pin.
Start the tractor. Using the hydraulic control lever, lift the mower frame assembly slightly and move the mower to the left to allow attachment of the left stabilizer. Place the stabilizer guide under the tractor's left lift link. Position the clamp over the link and tighten the nut firmly
Depending on the tractor type, install the clamp plate or push rod anchor assembly onto the left lower link. Install the push rod on either the clamp plate or anchor assembly.
Shift the mower assembly to the right to attach the right stabilizer. Place the stabilizer guide under the tractor's right lift link. Position the clamp over the link and tighten the nut firmly.
Raise the mower using the hydraulic control, then attach the mower lift spring to the spring links with the pins that have been provided. Lower the mower assembly and turn off the engine.
Remove the tractor power takeoff (PTO) cap and connect the splined end of the mower's drive shaft to the PTO shaft. Secure the connection with the snap coupler found on the yoke.
Rotate the leveling crank to lower the frame, ensuring that it is parallel to the ground. Use the leveling crank lock to secure the crank lever.
Jul 15, 2012 | Vacuums
Three point hitch wont lower, kubota l2550
Mine did the same thing. Below the front of the seat is a knob sticking toward the front of the tractor that is angled upward that controls the fall rate of the three point hitch. After searching the internet for a while I found what this knob is for and went out and turned it until the three point fell down. The knob is perfectly placed to bump with my foot as I get off the tractor (I have large feet and bump a lot of controls getting on and off) and I guess I had bumped it closed over time.
Dave
Jun 22, 2012 | Garden
I have a 4310. The three point lifts only under high rpm and won't lift any weight at all. Cleaned screen and replaced suction and trans filters. Still have problem.
A 4310s 3-pt should be able to lift approx. 1-ton at 24inches on the 3-pt lifting arm. I thought there was a hydraulic reservoir and a transmission reservoir and it is not uncommon to put the wrong fluid in one of those You might check that transmission fluid didn't get in the hydraulic tank.
May 16, 2012 | John Deere Seat 4210 4310 4410 4510 4610...
Hydraulic 2 post auto lift does not go up evenly
Don't know what make and model you have but most have two equalizer cables. These cables cab be adjusted. Raise the arms a bit and look at them. Tighten a cable to raise the low arm or loosen a cable to lower the higher arm.
You might check for a manufacture's web site as most manufactures put instruction manuals on their sites.
Also may inspect and make sure the rams are working properly.
Oct 20, 2011 | Cars & Trucks
Top worked fine yesterday but today tried to let down only clicked
It is a hydraulic pump that applies pressure to the 2 hydraulic pistons to raise & lower the top. So, check for something obstructing movement first.
The convertible top:
  • is motor-driven.
  • requires parking brake engaged to complete circuit for operation.
  • is equipped with a back window glass (42006) . The back window glass is permanently attached to the folding top back window curtain (52500) and cannot be opened.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged fluid reservoir.
  • Damaged folding top hydraulic cylinders .
  • Damaged folding top motor upper and lower hose .
  • Damaged convertible top regulator.
  • Parking brake not engaged.
  • Open power distribution box circuit breaker CONV TOP (30A), fuse junction panel Fuse 1 (15A).
  • Circuitry open/shorted.
  • Damaged convertible top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Convertible Top Does Not Raise/Lower
  • Open circuit breaker or fuse.
  • Damaged folding top switch.
Jun 29, 2011 | 1998 Ford Mustang
I have a lawn mower that has a hydraulic lift - and frequently it will not lift the mower deck or snowblower unless I push down on the lift assembly arm (it is connected to the mower by chains) while I...
Larry,
Tim
Dec 17, 2010 | Garden
Garden Logo
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
