Question about Fantom Vacums Lighting Canister Vacuum
How to remove canister from fantom vacuum 2510
5 Suggested Answers
SOURCE: Fantom Canister Vacuum parts
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12055&thid=723654
Posted by jaybird73 on Jun 30, 2008
Hi, Don. I'm in need of a part for my Fantom Canister. It's a little difficult for me to describe but here goes...the part is the small metal "pins" that are found in the connection between the hose and the motorized floor attachment. There are normally 2 found in that area, they are about an inch long and I guess they pass the electricity between the hose and attachment. Any help is appreciated.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sound so me that it could be a lower wand with the pins in the end or the part of the power nozzle and the part that the lower wand fits into is called the gooseneck and that can be replaced as well. If it is part of the hose then you may have to replace the hose and that could be expensive or over $100.00 or more, as an estimate. The best place to get the information is the owner’s manual under trouble shooting or to cal the Fantom factory of which I will provide for you @ the bottom; or your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
defrankond
  • 65 Answers
SOURCE: fantom fury vacuum
HOW DO I CHANGE THE BELT ON THE FANTOM® THUNDER® AND FURY®? a.gif fantombeltchange1.jpg
  1. Unplug the machine.
  2. From the front of the machine, remove the collection bin.
  3. Facing the back of your vacuum, remove each of the Philips head screws located above each of the rear wheels. (Figure 1)
  4. To remove the base cover, place your thumbs in the two screw holes in the back of the machine. Push forward and up on the screw holes to disengage the 3 cover locking tabs. Put the cover off to one side, and go to the front of the machine. (Figure 2)
  5. Check the drive arm for any black streaks which indicate residual rubber from the last belt. The drive arm is located on the right side of the motor. The easiest way to remove any residual rubber is with some nail polish remover on a rag or with steel wool.
  6. To attach a new belt, remove the brush from the base of the machine by pulling up straight up with two hands.
  7. Take the new belt and hook it over the steel drive arm. Pull back on the belt slightly, to create some tension.
  8. Put the brush inside the belt loop so that the track for the belt is aligned with the belt itself.
  9. Replace the brush by aligning the metal end so the points face downward. (Figure 3)
  10. Rotate the brush by hand to check that the belt is running freely and easily in its designated space between the bristle.
  11. Replace the cover by placing the nose in first. Once in place fasten with the two cover screws and then replace the collection bin.
Posted on Nov 30, 2008
SOURCE: My Fantom Lightning canister vacuum won't turn on
You need to turn over and remove the case to get to the motor.When you get to the motor you will see a white wire going to the motor from the switch,it has a white cover over the wire,pull this cover back and there is a small fuse that is probably blown.You can check this with a electrical tester.If this is not blown the heat sink that is connected to the fuse may be bad.These parts can be found at Radio Shack.
Posted on Mar 23, 2010
  • 147 Answers
SOURCE: hi I was wondering if
Hi Leslie,
The mother company is Euro-Pro or Shark.
My feeling from a service aspect, they are pretty cheap units, and when it comes time for a service, they are a little expensive to fix. You would be better off with another brand, such as Hoover or Eureka. That is my personal opinion and mostly because those two brands are using universal parts.
Good luck.
Posted on Nov 06, 2010
Euro-Pro Fantom FC-251 Canister Vacuum; Bought one of these 'gently used' at an auction. Would like a user manual if available.
You can download the manual by following the instructions on the following link. I used the security code to download it.
http://safemanuals.com/314159.php?k=4789186c8ac87e31888cf7e7294a3bd7&ID=347344&q=FANTOM FALCON FC251
Jan 08, 2011 | Euro-Pro Fantom FC-251 Canister Vacuum
I'm looking to buy the powerhead and hose for the fantom canister vacumm.
I have one for sale if you are still interested, and other parts for this vacuum. :)
Nov 01, 2010 | Fantom Vacums Lighting Canister Vacuum
Looking for the wand for the fantom lightin canister vacum, anybody know where I can find one.
they have gone out of business so I would check on craigs list and used vacuum stores.
Oct 07, 2010 | Fantom Vacums Lighting Canister Vacuum
Cant find one
Hello. You can call the Fantom company directly at 800-798-7395. Or use their website http://www.fantom.com/fantom/default.aspx
please rate my answer as very helpful. thanks. Joe800-800----
Apr 21, 2010 | Fantom Vacums Lighting Canister Vacuum
My Fantom Lightning canister vacuum won't turn on at all, worked fine last time I used it.
Jan 12, 2010 | Fantom Vacums Lighting Canister Vacuum
Nedd power head wand for Fantom Model BPSRLC51
the best bet would be to look on ebay. the fantom line was discontinued
Jul 28, 2009 | Fantom Vacums Lighting Canister Vacuum
Go Ahead. Use Us.
Jun 30, 2008 | Fantom Vacums Lighting Canister Vacuum
Fantom Canister
It sounds like you have a hose problem. You should be aware that the Fantom company went bankrupt many years ago. I know that the Fantom name was bought by another company and there may be Chinese units sold under that name, but service and parts availability is an issue. There may be an issue with the power delivery to the powerhead. This is through the hose, from the canister connection and down the wand assy. You should check the continuity from the canister down to the powerhead.
Dec 12, 2007 | Fantom Vacums Lighting Canister Vacuum
Fantom Vacums Lighting Canister Vacuum Logo
23 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
