Question about Nortel 1140E
PHONE STARTING THE DHCP NEED A PASSWORD OF WHICH I DONT KNEW.
WHEN THE PHONE START AUTOMATICALLY ..ONCE YOU PRESS MENU BUTTON.IT WILL ASKE YOU ABOUT ENTERING PASSWORD..ON THE DISPLAY ..ITS ****STARS ON IT, PLUS TAP OK AND CANCEL
Default password 26567*738
Posted on Nov 27, 2009
    Problem Solver:
  • 8 Answers
The password you require is documented in the Nortel NTP.
Posted on Jun 26, 2009
Sim Lock Problem
download samsung kies here is the link
http://www.samsung.com/uk/support/usefulsoftware/KIES/
install kies you might need it. But for now here is what you need to try. Power of your phone. Then your gunner need to hold the home key on bottom front of phone and the up key on left side of phone and the power button it shud give u a menu once booted. On this menu use your side keys on left of the phone to scroll down or up. Scroll down to (wipe cache partition) PRESS The POWER BUTTON. THEN USING ARROW KEYS GO TO (wipe data factory reset) AND PRESS THE POWER BUTTON. THEN GO UP TO (reboot system now) Press POWER BUTTON TO ENTER. Once this has done its thing your phone will reboot and start to go through the phone setup. At the end of the setup is were it will ask for you to setup samsung account at this stage you can sign in, or skip this, or create new account. Try this let me no how you get on.
Apr 21, 2016 | Samsung GT-C3222
Tip
Windows XP: How to release and renew IP addresses
IP addresses can either be assigned manually or automatically. When they are assigned automatically, a DHCP (Dynamic Host Configuration Protocol) server hands them out and determines which computer or other device gets which address. This process usually flows smoothly, but there are times when you may need to release or renew an IP address even when using DHCP.
There are several ways to release and renew IP addresses in Windows XP. Each procedure is described below.
From the system notification tray:
1. Right click on the network connection icon in the system notification tray.
2. Select Repair. Windows will automatically release the current IP address, reset the network connection, and request an IP address from the DHCP server. (The new IP address that gets assigned may be a different one from before, or it may be the same one.)
From the Start menu:
1. Click the Start button.
2. Right click on My Network Places.
3. Select Properties.
4. Right click on the network connection that is currently in use.
5. Select Repair. (If you choose a network connection that is not in use, Repair will be grayed out.)
For either of the above methods, you can release and renew your IP address manually by clicking Disable instead of Repair, and then right-clicking and choosing Enable.
From the command prompt:
2. Click Run.
3. Type "cmd" and press [Enter].
4. At the command line, type "ipconfig /release" and press [Enter].
5. Type "ipconfig /renew" and press [Enter].
6. Type "exit" and press [Enter].
on Feb 02, 2011 | Microsoft Windows XP Home Edition
I cannot pair my motorolla bluetooth with my LG VX9200
This has worked for 99% of bluetooths . Turn off bluetooth complety.Go to search for devices menu on your phone but dont search yet.. Press and HOLD the power button on the bluetooth do not let it go. when the bluetooth starts blinking (some will blink blue some red some both) When it starts blinking keep holding power button(on bluetooth) while doing this then do search for devices on your phone when should see it pop up. when you go to pair therm it will ask for password most are default 0000.
Dec 14, 2010 | LG enV3 VX9200 Cell Phone
Reset password
Plug the phone in and allow it to boot up. Once the home screen is displayed, press and hold the 4, 6, 8, and * keys for about three seconds, or until you hear an audio alert and the phone asks you for a password. Enter 456 (default Admin password) and the phone will default itself. If the password has been changed, and 456 does not work, enter the MAC address of the phone as the password. Entering the MAC address of the phone will only reset the Admin password to the default, so it will probably be necessary to repeat this procedure, entering 456 the second time, to factory default the phone.
Dec 04, 2009 | Polycom SoundPoint IP 550 IP Phone
I lost my l6 password
dont worry if you have lost your unlock code.
you can use the security code in place of the unlock code.
what you need to do is just press the Menu button (the "-" button just above the ) when it asks you to enter the unlock code.
now it asks you for the security code. if you have not set the security code, just enter 6 zeros. (000000).
if you have changed the security code, just enter it.
now you can set a new unlock code even you dont know rhe old unlock code.
go to settings --> go to security--> goto New Passwords-->select unlock code..
it asks you to enter the old code, just press the menu button, it asks you for the security code, enter it, now enter a new UNLOCK code of 4 Digit.
Hope this helps..
Nov 14, 2009 | Motorola Mobility L6 Cellular Phone
How can i password protect my sony ericsson w580i in standby mode ??????? plz reply me!!!!!!!!!!
It can be a pain when buttons on your phone get pressed when in your pocket or bag. You can lock your Sony Ericsson W810i's keypad by pressing * then Lock keys, or you can set it to lock automatically after a short time.
Enter the main menu by pressing the centre button, then highlight Settings and press Select. Scroll down to highlight Locks and press Select. Scroll down again to highlight Automatic keylock and press Select. Now choose On and press Select.
For added security, you can set your phone to lock with a numerical code. This means that if you should lose your phone, it will require a passcode to be switched on again. You have three options: On, Automatic and Off. ‘On’ means that you will be required to enter the passcode every time the phone is switched on, where as ‘Automatic’ will only require a password if the SIM is changed.
To activate any of these functions, hit the centre button to enter the main menu, then scroll down to the Settings icon and press Select. Now scroll straight down to Locks, press Select, then choose Phone lock and press Select. Before you begin, you’ll need to change the code to something only you know. By default the Phone lock code is set to ‘0000’ so highlight Change code and press Select, then enter ‘0000’ and press OK. Now you’ll need to enter a new code twice in order to activate it.
Once you’ve changed the code scroll up to Protection. Press Select to adjust the protection level. Choose from On, Automatic and Off, then press Select. You’ll be required to enter your passcode to continue, then you’ll see a confirmation message.
Jun 26, 2009 | Sony Ericsson w580i Cellular Phone
Have a motorola v9. Cant remember the password and need to know how to bypass the lock code so i can master reset the phone and start using it again.
try pressing the menu button when the phone asks for the code than it will change to a security code and the security code is set default to 6 zeros [000000]
Mar 12, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Dont know the password and user name
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
Nov 12, 2008 | D-Link AirPlus DI-524 Wireless Router
Starting DHCP screen won't clear
Try using 26567*738 as the default password for the 1120E and 1140E IP phones.
Nov 30, 2007 | Nortel 1140E
Nortel 1140E Logo
1,580 people viewed this question
Top Nortel Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
J John
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
