Question about Garden
I have an old snowblower (ca. 1980's?) that runs like a top - the only problem is that the auger drive chain pops off the rear (smaller) sprocket in heavy snow, no matter how tightly (or loosely)
  • Kenny Vee Apr 21, 2013
    The snowblower is a Montgomery Wards single stage 5/20
    Problem Solver:
  • 29 Answers
First remove the chain--- lay it flat on the floor --streched lengthwaze . grab either end and pull out and push back--- if chains length moves more than a quarter of a inch ---replace the chain. Next inspect the sprokets, if they are worn inward on the side they will let the chain drop on too far making the chain jump and rattel as it runs and this will throw the chain. Next inspect allignment of each spoket to the next sprokets with belt drive the belt will flex and this is not critical with chain drive this will load one side of each spoket causing the chain to jump off.
Posted on Apr 20, 2014
How to replace drive belt on a 1993 harley davidson heritage softail classic?
To remove a Softail drive belt FIRST remove the rear wheel then remove the primary chain, the clutch, the engine compensating sprocket, and the chain adjuster as an assembly, then remove the primary chaincase housing, place a support under the rear fork and engine, remove the pivot shaft and spacer, slip the drive belt off from the transmission sprocket.
To replace a Softail drive belt FIRST not that all belts, used or new, must never be formed into a loop smaller than 5.0 in. (130 mm), and must never be bent backwards because this can severely weaken the belt and cause premature failure if it, then install the belt over the transmission sprocket, install the pivot shaft and spacer, remove the support holding the engine and rear fork, install the primary chaincase housing, the primary chain, the clutch, the engine compensating sprocket, and the chain adjuster and the primary chaincase cover, fill primary the primary chaincase with oil, install the rear wheel, align the rear wheel and properly adjust the belt tension to the specified deflection.
Apr 28, 2014 | 2000 Harley Davidson FLSTC Heritage...
How to replace drive belt on 1993 harley davidson?
Is it a softail????
Apr 28, 2014 | 2005 Harley Davidson FLSTC - FLSTCI...
Do you have any idea how to check the chain adjustment on a 2002 Dyna Low
hi,
Sooner or later, every bike will need a new chain and sprockets. Once a chain begins to wear, its pitch changes and wears the sprocket teeth. Then the chain begins to wear even faster. Then it's time for a new chain, and a new pair of sprockets.
The rear wheel on my motorcycle had been misaligned (I had used the inaccurate etched indicators on the swingarm-rather than a ruler against the sprocket-to set wheel alignment) and ridden hard through a gritty, salty winter. The rear sprocket was in rough shape, and the chain was making lots of popping sounds as the bike went down the road.
Changing a chain is a fairly basic job that requires a chain breaker / riveting tool and whatever is needed to remove the rear wheel and sprockets. It's nice to have a blow torch and a torque wrench on hand for this job, too.
The ingenious Terra-X chain tool is made in Australia out of tool steel, and weighs just 150 grams. A big hollow bolt threads into the bigger of the two holes, and is used when pressing outer plates onto new master links. A smaller bolt with a pin can thread into the hollow bolt, and is used to push link pins out of old chains or to peen new master link pins by pushing them against a grub screw threaded into the steel body's other hole. That little grub screw with a rounded steel end screws into the smaller hole of the chain breaker. It fits into and peens the hole of the new master link.
When changing a chain, the first step is to loosen the bolts on the front sprocket. It's good to get those loose while the chain is still on the bike, partly to avoid putting undue stress on the transmission, and partly to avoid getting deep into the job and finding that the front sprocket bolts are stuck. In this case, the small allen bolts needed a bit of heat to come undone.
After the bolts are loose, it's time to break the chain. With the Terra-X chain tool, you remove the small grub screw and use the small bolt with the pin to push out one of the chain's pins. No grunting or swearing required.
Then comes sprocket replacement. Six nuts on the rear sprocket, the two bolts on the front sprocket, and that step is done. I had a torque wrench handy, so I could get the torque values just right when putting everything back together.
The next step is the big one: installing the master link that joins the ends of the new chain together. The master link comes with a little bag with some X-Rings, a master link, and some sticky tan lube. Smear the lube on the pins and inside the X-Rings, then begin to assemble the master link around the two ends of the chain, making sure to get the X-Rings in the right spots.
Pressing the outer plate onto the master link is the hardest part of the job. I removed the pin bolt from the Terra-X tool and used the hollow bolt to push the outer plate onto the master link's pins. It took a few tries, but eventually I got it in the correct position.
After the sprockets are on and the master link is in position, the master link's pins need to be peened. With the Terra-X, the pin bolt pushes the master link pin against the grub screw's steel ball, and flares the pin. It takes a lot of effort-mostly because it's not easy to get a lot of leverage on tools when they're underneath a motorcycle.
Position the wheel for proper chain tension, torque everything to the correct specs, and you're back on the road. The new chain is smooth, nearly silent, and ready for thousands of miles of high-speed running.
May 14, 2011 | 2000 Harley Davidson FXDWG Dyna Wide Glide
I lose power and stall when i engage clutch to spin snowthrowing blades on my mtd 24" two stage snowblower. any way to fix?
You probably have a small rock or stick jammed in the smaller throwing auger. Carefully rotate the small auger backwards using a stick/board and tapping with a light hammer till the jamming object pops out. Be careful not to place your hands or fingers in even if it is not running. Worst case scenario the worm gear that rotates the larger auger is broken and jammed and needs replacement. If both augers move freely then you will have to remove the cover under the motor and inspect the belt drive mechanism.
Feb 21, 2011 | Mtd Products Yard Machines 158CC Tiller
How to increase top end speed - 2007 Kawasaki Ninja EX250R
you can change the sprockets.If you go to a 16 tooth front sprocket. two teeth on a front sprocket is like droping 4 teeth on the rear. You could drop 2 teeth on the rear sprocket but a 43 tooth is probably harder to find. the usual choices for front are 14,15,16 tooth.
For the rear they are 44,45,46 tooth
The way to remeber gearing changes is on REAR sprocket is smaller=faster and larger=slower top end.
the FRONT is OPPOSITE to the rear smaller=slower and bigger=faster.
You may have to lengthen or shorten the chain depending whjch way you go.
Mar 20, 2010 | 2008 kawasaki Ninja 250R
Broke the chain , on snowblower
top idler sprocket was out of alignment,staitened plate it was attached to, then chain was running true and went on just fine. it was an old wheel horse snowblower.
Dec 15, 2009 | Garden
Can you tell me how to change the chain and sproket on a '07 Honda Shadow VLX 600cc???
I don't have any experiance with your particular bike but have changed them on many different bikes to date. You should first purchase a new chain and sprokets and compare them to the existing one prior to removal as you won't be able to refit the old one safely. You are checking for the correct amount of teeth on the sprockets and the amount of links in the chain.
Once satisfied that you have the corrrect parts. Remove the front sprocket cover and locate the front sprocket. Most large bikes will have a large nut holding it on. Smaller bikes will use a tab washer and or circlip. If you have a large nut i find the easiest way to loosen it is to put a lock or similar through the rear wheel to immobilise it and then with a breaker bar loosen the nut. Once free change the sprocket over, then move to the rear sprocket loosing each nut in turn but making sure you are appling pressure to the nut squarely as it is easy to cross-thread these smaller nuts. This is best achevied by leaving the wheel on the bike until all the nuts are free. Remove the wheel and change the rear sprocket. Once done you are now ready to remove the chain from the swing arm. You can either cut it off with an angle grinder or you a chain link tool as i do.
Now the chain is split. Connect the new chain to one end and feed it through. Detach the new from the old and then rivet both ends together using a chain tool as described in the tools specific instructions.
Regards
Chris
Nov 06, 2009 | 2005 Honda VT 600 CD Shadow
Putting the chain on 10 speed after changing flat tire
Wind the chain through the rear sprockets, grab a hold of the rear sprocket and rotate the smaller sprocket towards the pedal, that should give you enough slack to put the chain on the front sprockets
Sep 22, 2009 | Cycling
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
