Question about Sanyo SCP-7050 Cellular Phone
SCP-7050 screen reads backwards like a mirror image
On my Sanyo SCP-7050, the inside screen reads backwards like a mirror image. The outside screen has black and white bars that look like a barcode. It doesn't do it all the time, just sometimes. As far as I know, it has not gotten wet or had any extreme abuse. I've only had the phone for 3 months. Any suggestions?
  • 1 more comment
  • Anonymous Nov 19, 2007
    screen reads backward like a mirror image
  • Anonymous Nov 26, 2007
    I have had a problem with my SCP-7050's display. It will either be completely white screened with nothing on it, or it will be a mirror display where everything is backwards. I have not abused the phone at all.  If you have found a fix, please post about it.
  • twillio Jun 07, 2008
    exact same problem... weird.
I had the same problem with my phone, had it fixed once under warranty a few months later had the same problem. They told me it would cost a fortune to fix, I was about ready to give up until i examined the phone a bit further, it seemed as though the contacts on the battery were somewhat worn, I simply packed some paper between the battery case and the top of the battery, seemed to fix the problem for now.
Posted on Nov 29, 2009
I had the same problem after a power surge. The phone didn't right itself until I literally lobbed it against a wall lightly. It immediately started operating normally. Wow.
Posted on Oct 09, 2008
I have/had the same problem. Out of no where the screen look funky as if it had gotten wet or something, even though it hadn't. When I took the battery out and put it back it if fixed it temporarly, but then it started happening faster and with a total white screen where I couldn't do anything.
I think the battery contacts are at fault here, there appears to be nothing actually wrong with the screen itself. I cut a small piece of a plastic twisty tie and crammed it between the case and the top of the battery. Seems to have fixed it, I'll post back if I start having problems again.
Posted on Dec 16, 2009
I have a similar problem my screen goes crazy often. It goes white, sideways barcode, flying collors and choppy display like a frozedn computer the screen splits down the middle when problems ocur. I did not abuse my phone at all. As a matter of fact i only had the phone 4 hours before it broke.
Posted on Jul 29, 2008
Your phone should have a one year warranty from sanyo. Contact them
Posted on Sep 18, 2007
Glad to know I'm not the only one. Mine did the same thing 53 weeks after I bought it. It showed reverse/misaligned images with a green hue on the main screen and the barcode like image on the outside screen itermittantly, and has since gone to a blank white. I'm going to contact Sprint today, it's worth a try.
Posted on May 27, 2008
SOURCE:
How unlock qwest sanyo scp 7050
you can unlock your sanyo scp 7050 using codes. you can get the codes from Classicunlocking.com
May 03, 2012 | Sanyo SCP-7050 Cellular Phone
How do I unlock this old Sanyo SCP-7050 Cell Phone so I can use it with AT&T??
you can unlock your sanyo scp-7050 using codes. you can get the codes either from your service provider or from other online providers like Unlocking4U.com
Sanyo scp-7050 unlock code
You can Unlock SANYO SCP 7050 easily using the unlock code from here Simpleunlocking.com/sanyo-scp-7050/rs16wp9/
Apr 18, 2012 | Sanyo SCP-7050 Cellular Phone
Trying to enable blue tooth but my display is scrambled Looking for a key sequence
I am also in need of a key sequence to enable the bluetooth on my SCP-7050. My ribbon is damaged, and screen is also white. I need to extract important work numbers to my new phone via blue tooth. Any help would be greatly appreciated ! Thank You!
Dec 27, 2010 | Sanyo SCP-7050 Cellular Phone
Have sanyo scp 7050. Called sprint to change the
this sounds like a device issue it can be reflashed at a service and repair store for no cost if you have insurence
Jan 17, 2010 | Sanyo SCP-7050 Cellular Phone
Sanyo SCP 7050
need help with the above please
Jul 09, 2008 | Sanyo SCP-7050 Cellular Phone
Sanyo scp7050
When I close my Sanyo SCP-7050 cell phone, the screen will go blank for a few seconds. Then, it will come back on and state that it's "Looking for service..." and then "Entering Sprint service area." After that, everything is back to normal.
It doesn't happen all the time but just enough to be frustrating.
Jan 24, 2008 | Sanyo SCP-7050 Cellular Phone
Ringers For SCP 7050
Use a program suchas Tonethis.It is completely free and you can post mp3's pictures or games to a web-enabled cellphone.
Jan 19, 2008 | Sanyo SCP-7050 Cellular Phone
Sanyo SCP-7050 Cellular Phone Logo
1,012 people viewed this question
Top Sanyo Cell Phones Experts
Wess Rohadfox
Wess Rohadfox
Level 1 Expert
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
