Question about Hayward Pool & Spa
Hayward filter top stuck - Hayward Pool & Spa
    Top Expert:
  • Hayward Master
  • 8,163 Answers
Release pressure or drain water out open bleeder valve on top
Posted on Jun 05, 2016
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: is the Hayward s210 pro series 21" top mount above
Thank you for posting your question here on Fixya.com.
32' round by how deep? Flow rate is how you size a filter so with total gallons you can calculate how many per minute will add up to the whole pool being turned over is 6-8 hours. The pump and filter are then sized for that required flow...Assuming the pool is an above ground ~4' average depth then total gallons would be about 24,000 gallons. For an 8 hour turnover you would need about 50 gallons per minute. The 210T, T for top mount, is designed to handle up to 44 gallons per minute and turn over a 21,000 gallon pool in 8 hours or a 26,000 gallon pool in 10.
What that basically means is that using a 210 on a pool 32 x 4 would be pushing it. It will work but you will end up backwashing more frequently which raises the overall cost of running the pool. If it is not to late a 24" filter would be better; especially if you have periods of time in your pool season where heavy amounts of debris such as pollen get into the water. A 21" filter won't handle any over a normal filtration load.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Posted on Apr 29, 2011
I cannot read the diagram on top of my hayward sand tank filter pro-series s244t filter,close,waste which way
go to westport pools.com and see if you can find a picture of it or go to hayward filters..
Jan 06, 2014 | Hayward SAND FILTER, PRO SERIES
PRESSURE LEAK AT SEAM ON HAYWARD FILTER,TRIED SEALING IT FROM THE
You can check with Hayward for warrenties, but it's time for a new filter.
Jun 22, 2010 | Hayward S220t Top Mount Pro Series Sand...
Water leaking out the top
Here is a copy of the users manual for these pool filters. It has detailed illustrations about how the filter should be put together.
http://www.backyardcitypools.com/images/hayward/perflex-system-manual.pdf
Jun 21, 2010 | Hayward EC-40 DE Pool Filter with pump
I bought my above ground swimming pool package in 1990. My Hayward sand filter is a top mount and has a lateral assembly w/center pipe in side of it. The pipe is broken at the top and I need to purchase a...
I believe that the owners manual has a parts listing to help you distinguish the part that you will need to buy. However, if your pool filter was purchased in 1990, you are probably going to need a new filter. Most do not last over 20 years.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 01, 2010 | Hayward SAND FILTER, PRO SERIES
Can't get my hayward filter lid off. It turns a little bit, then pops and won't come off....it's stuck. How can I get it off?
Sounds like it is stripped. Hope it is the cap and not the part the filter is in. If you are very careful you may get the top off by taking 2 items you can pry with. Either screwdrivers or something similar. Have another person help if there is room. Place one of the pry items under the edge of the cap and put a little upward pressure on it. Have another person do the same thing on the opposite side. Now, carefully start to work the top off. Allow yourself time and patience. It will probably turn with difficulty but keep going. I assume it is plastic and maybe when you take the top off you will cut some new threads. They may allow you to use the same top or not, good luck...Lee
Oct 07, 2009 | Hayward Easy Clear 40 Sq Ft Cartridge Pool...
I have a 1 year old hayward sand filter and now everytime i vacuum for a short period of time it discharges dirty water back into the pool
your setting is more than likely is not in the right position handle on top of filter has a sprocket under handel which is either not seated or has damage to it try turning handle to different positions several times sounds like you are stuck on recirculate
Jul 11, 2009 | Hayward SAND FILTER, PRO SERIES
How do I chabge the sand in my s-200 Hayward sand
take top off open bottom drain use a small wet vac hose to get as much out through top out be careful not to damage filter bars wash the rest out through bottom drain with a garden hose
Jul 02, 2009 | Hayward SAND FILTER, PRO SERIES
Pool & Spa Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
