Question about Point 65 Kayaks Apollo SitOnTop Kayak Bow Section, Red
Wind blew over part of my kayak and broke one of the ratchet buckle that conects to the other peice of the 3 part kayak. Where can I buy this peice?
Need a new ratchet buckle piece
The peice that conects the shifting cable to the shifter broke. what is that peice called? Where can i get it?
I don't have a name for it, but if you want a new one, it's a dealer item.
You could probably find one at a wrecking yard.
Mar 13, 2011 | Saturn SL1 Cars & Trucks
Buckle on 5 point harness of stroller broke.
Hi I have a trends for kids stroller and I los the harnes, where can I buy those
Feb 09, 2010 | Chicco Cortina Travel System - Discovery...
Can you confirm how the straps are correctly to be used to hold the surfboard in place?
Place pads around your cross bars, thread straps over the board and under the bar on the far side and then over the board with the buckle end on top of the near side of the board. Then wrap the other end under the bar and 1 time around on the near side, thread through the buckle and pull tight....repeat.
Sep 28, 2009 | Da Kine Car Rack Pad Set Surfboard Bag...
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Which kayak to buy
Plastic and fiberglass are the two materials the majority of kayak manufacturers are using today. Plastic kayaks are lower priced, have the largest selection of models and are known for being tough. The down side of a plastic hull is that it doesn't hold an exact shape, it's softer (therefore slower). It's close to weighing the same as fiberglass but you can't perform field repairs on it. Fiberglass is approximately $1000 dollars more for the equivalent-length plastic boat, but the hull is much stiffer, faster through the water and you can repair it. The down side to fiberglass is that it's more expensive, and if you drop it off the top of your car, you can crack it
Dec 01, 2008 | Wilderness Systems Pungo 140 Kayak
Essential equipment
The essentials are: 1. boat. 2. paddle. 3. sprayskirt. PFD - personal floating device (life jacket).
Cosco Buckle Broken
Bought a new car seat
Sep 26, 2008 | Cosco 02-442
Mtx blue thunder pro3002
Take this apart and look at the magnet wire windings look for any thing broke or burnt. If not it is very likely it is more cost effective to buy new.
Feb 01, 2007 | MTX Thunder 2-Channel Amplifier 502 Car...
Point 65 Kayaks Apollo SitOnTop Kayak Bow Section, Red Logo
262 people viewed this question
Top Point 65 Kayaks Clothing Accessories Experts
Da Doc
Tom Chichester
ray gallant
Are you a Point 65 Kayaks Clothing Accessory Expert? Answer questions, earn points and help others
