Question about Dryers
Kenmore model 970-c84172-00
Serial no. x034913093 Fault code F03
bigg t
  • 640 Answers
SOURCE: Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Posted on Sep 29, 2007
  • 979 Answers
SOURCE: Fault code F03
No drum rotation signal. A shop visit is required. Sorry..accordianman
Posted on Apr 26, 2008
  • 13 Answers
SOURCE: code F03
I just had this same problem, it was a bobby pin stuck in the drain motor.... hope this helps
Posted on Mar 29, 2009
vickygomar
  • 460 Answers
SOURCE: Kenmore Dryer F 26 fault code
code F26 Door switch error
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for 5 secondes.
==========The following information is for technitions only========
Possible Couses/Procedure
* Door not open during consecutive cycles.
1.- Open and close the door.
2.-Veryfy CCU operating by running a Diagnostic test or any cycle.
3.- Check door switches contacts.
4.- The resistenve of both door coils (between pin 1 nad 3) should be aprox 320_O_
hope this information will help U
Are you happy with my help?
Posted on May 12, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Kenmore elite range, model 970-698593, Error Code E015
Just asking if your model number is correct. I do not find 970 models but do find 790 models. If it is a 790 model there can be aproblem with the door lock on the oven door. You may want to check to see if all the shipping materials have been removed from the door lock / latching area. I would recommend that you review the installation instructions in the owners manual, paying particular attention to the removal of shipping materials.
Adittionally if the problem presists it says to replace the Electronic Range Control (ERC) This is not a cheap part! Good thing it will be at their expense including the repair service call..
Hopefully you have already called for warranty service? We both know a brand new oven should not be producing any error codes. If you have not called for warranty service you do so now. Make sure to tell them that you already have talked to customer support and that unplugging the unit for ANY period of time made no difference in the error code.
Thanks for choosing FixYa.
Kelly
Posted on Aug 01, 2010
What does Fault code F10 on a Kenmore Range, Model #970-678421, mean please?
run away temp either temp probe or EOC board is the problem
Jan 30, 2017 | Kenmore Ovens
Kenmore Fridge Model # 970-65832T, Serial # BA64621410 Want to know age of Fridge
did you not write it in the owners manual where it tells you to for warranty purposes
Mar 19, 2015 | Kenmore Refrigerators
How do I stop my kenmore dryer, model 970-c87172, from beeping? Drying, cool down, wrinkle rid and clean lint filter lights flash 3 times. Start light doesn't flash at all. It does this even
Hi Brenda
First off It seems that you model is not correct. Kenmore model numbers start with 3 number followed by a . and then some more numbers. Most Kenmore laundry numbers start with 110.xxxxxxxx. The number you have looks like a serial number which is no help.
Oct 19, 2014 | Kenmore Dryers
Fault code f03
Not sure that the model you have given is correct, but generally F03 on an older Bosch machine indicates the the pump out has exceeded the allocated time, check the filter, hoses and outlet connection for debris, foreign objects etc.
Feb 24, 2013 | Bosch Washing Machines
F03 DISPLAY ON MY NV-SD300 PANASONIC
go to panasonic.com/vcr and give them the model/serial # and ask what the F03 error code means and they can give you a solution for the problem.
Jerry
Aug 27, 2012 | Panasonic Televison & Video
Kelly
Aug 01, 2010 | Kenmore Kitchen Ranges
Fault code F03
Apr 23, 2008 | Televison & Video
Sep 28, 2007 | Ovens
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Dryers Logo
49 people viewed this question
Top Dryers Experts
