Question about Bosch SHE6AF05UC Builtin Dishwasher
Error code 24
Spindle test Failed (Error code: WCD44-RVH)
Spindle usually refers to the spinning axis of the carbon disks or the platters. The disks are likely not spinning and a drive replacement is required.
Jun 25, 2014 | Dell Inspiron 530 Desktop Computer
Magiccard Rio printer is giving error code 24:24
Error code 24:24 means that the sensors need to be replaced. This requires sending the printer back to MagiCard for them to replace the sensors.
Mar 01, 2013 | Magicard Rio Card Printer
FDB4315LFC2 ERROR
Hello - Typically the "ER" code displayed on your unit does typically indicate a shorted out control panel. This can happen by excess moisture getting into the control area. Let the unit dry for 24 hours with no use, and see if the display error code erases itself. If it does not, this unit will require the repair of a professional to move forward accurately.
Oct 25, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Rio pro error code 24:04
Hi Magicard Rio Pro message:
"General Error : Contact technical support, quoting error 24:04".
Somebody help me?
Jun 28, 2012 | Magicard Rio ID 2 Card Printer
Error code 24
2,4 is one of 5 error codes and means:
2blink-then 4 blink---------vertical circuit problem
The set may have a loss of sweep or even Glycol may have leaked from the picture tube above it onto the board in that area.
Vertical circuit is on middle board at front right edge.
Jun 16, 2012 | Mitsubishi WS-55311 55" Rear Projection...
1992 Jaguar XJ6..vcm error codes
code 24 is the ignition amplifier circuit
Sep 08, 2009 | 1992 Jaguar XJ6
Error code
throttle position sensor mal function
Mar 16, 2009 | 1987 Dodge Aries
Maytag Epic Z frontloader Error Code F20 Help Please!!!
i also have a magtag epic z &f 24 error code is on my washer. i don't know what to do.
Jul 01, 2008 | Maytag Washing Machines
Bosch SHE6AF05UC Builtin Dishwasher Logo
20 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
