Question about GE Profile Harmony DPGT750GC Gas Dryer
Gas dryer is not drying the clothes - GE Profile Harmony DPGT750GC Gas Dryer
    President:
  • GE Master
  • 1,922 Answers
It can be the ignitor as described above,or the gas valve coils on the gas valve getting weak or gone completely,or even the high limit thermostat on the burner housing open and also the flame sensor next to the high limit but these rarely go bad,the thermal fuse can be bad but on these if this goes out the whole unit quits and it sounds as though it still turns just no heat
Posted on Apr 28, 2013
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 30, 2010
  • 70 Answers
SOURCE: Gas Dryer not working properly
bad thermal sensor needs to be replace. But not available. sorry
Posted on Jun 07, 2012
Tumbles but does not dry
When you put your wet cloths in the dryer close the door. You should then turn on the dry cycle you wish, not the fluff option as there will be only air and gas dryer will not heat the cloths. Wait 30 ~ seconds after the dryer is turned on and listen for the gas to ignite and begin warming and drying the cloths. If you hear no bump sound like the ignition of the gas, then you have an ignition issue. It will require replacing the ignitor. All the best and good luck. Hope this helped.
Oct 02, 2012 | Maytag Neptune MDG5500AW Gas Dryer
What is automatic dry miser
What the automatic dry miser is, is a sensor that measure how dry the clothes are and will adjust the time its going to take to dry the clothes throughout the entire cycle. If at the beginning it estimate it will take 40 minutes to sry a load but they are dry in only 25 minutes the dryer knows the clothes are dry and cuts the dryer off. Saving 15 minutes of unneeded gas and electric that it would run and waste power and gas since the clothes were dry already.
GENE
Aug 18, 2011 | Whirlpool GGW9868K Gas Dryer
My LG dlg2532 takes forever to dry clothes. When the drying cycle ends, the clothes are still quite damp. It's a gas dryer and the dryer seems to be getting gas since it does eventually dry the clothes...
How long are the vents? do they go for miles in your house?(sarcasm) Does the dryer have good ventilation? Check the vents again and make sure it is clear.
May 27, 2010 | LG DLG2532 Gas Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Gas dryer wont dry close
replace the gas valve coils. they sit right on top of the gas valve. they are black and round, and clide down over a shaft. remove screw from plate holding them, and slide them up and off, replace, and it will run....turn gas off while working on unit:)
Sep 16, 2009 | KitchenAid KGYS750LQ Gas Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer not drying clothes
Hi, Dryers are simple machines to fix yourself so the main reasons dryers do not dry cloths is listed below.
1. Make sure the vent is clear from obstruction of lint built up by taking off vent and make sure the vent flap is opening when dryer is on, beware most house fires are caused by neglect of dryer vent!
2. People allot of times overload machine which causes cloths not to dry.
3. Electrical Repair Needed: one of the thermostats in the dryer are defective
May 02, 2009 | Dryers
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer not drying clothes
This problem doesn't sound right, but you could have a bad moisture sensor.
May 19, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
197 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
