Question about SanDisk Sansa View 8GB MP3 Player - Black
Volume/Selection wheel doesn't work when rotated
Volume/Selection wheel doesn't increase or decrease volume or change file selections when rotated. Pressing the 4 quadrants still operates fine. How is the back safely removed to access the wheel and clean the contacts? Would this correct the problem? Thanks for your response/recommendation.
    Problem Solver:
  • 20 Answers
I think this is a hardware problem. else u cn try formatiting.bt beware of it, if u are ok with ur current problem, then dont format. formatting will delete all the data on it. else u can chek for formatting.
Posted on Nov 24, 2013
2 Suggested Answers
SOURCE: mp3 wheel will not rotate
Then I guess you should just use the buttons instead. I hope my advice helped, lol.
Posted on Aug 23, 2008
How to increase brightness without fn+f6 keys because for now the f6 key is not working
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
Oct 08, 2012 | ASUS EeePC1000 1000H 1000HA 1000HC 1000HD...
Mitsubishi WD-52525 projection TV volume control
Check owner / operator manual for "panel lock" selection or
go through menu pages until you spot it........
This selection is made so guests or children cannot operate tv.
In case this suggestion fails, you might try hard reset = unplug
AC cord overnight,then try again...........T.
Nov 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
My 8350 was working fine now i cannot hear the phone ring and cannot hear text alerts
make sure the phone isn't on silent by checking the volume level.
Jul 24, 2011 | Blackberry Curve 8350i
My Amplifier is in good working condition, except for the volume control has gone weird Using the remote, you can increase volume, but not decrease volume. On the unit, rotating the volume control...
Cleaning the contacts may help. The volume knob should pull off. Once its off use a non-flammable contact cleaning spray to clean the contacts behind the knob.
Electronics and automotive stores should have this.
May 16, 2011 | Onkyo TX-DS494 Receiver
How do I turn down the volum ring on the phone
Check for buttons on the side of the phone. There should be an up and down button to change the volume either way. If that doesn't work look for setting and then sounds. From there, it should be possible to find a way to change the volume of the ringtone.
May 05, 2011 | Cell Phones
How do I increase the volume on my Nokia 1661?
There are 2 types of volume in your nokia phone that you can increase or decrease.
The first one is the ring tone volume. You can either increase or decrease your ring tone volume by pressing the menu key then go to settings, go to profile, select any desired profile go to personalise go to ringing volume, then increase or decrease by using the navigation button to the right or left.
The second way is to increase or decrease the volume of the speaker of your phone which i think is the cause of your question (this volume enables you to hear clear and loud the person on the other phone). You increase or decrease the volume by making a call, as soon as the call starts ringing, press the navigation key to right to increase the volume or to the left to decrease the volume.
Jan 19, 2010 | Nokia 1661 Cell Phone
Light-up volume bars on the hp pc notebook dv7 1132nr
Hi Folks....
If you are talking about the Quick Launch buttons of the Notebooks from where we usually increase, decrease or mute the Volume, the lights will be still and will not increase or decrease with the increase or decrease in Volume.
However, you do have a utility which should be preinstalled in Notebooks called HP Quick Touch which shows the bars on the Display when the volume is Increased or Decreased  using the Quick Launch buttons. This application is not compatible with Windows Vista 64 bit edition.
The HP Quick Touch application is available for download from the link below :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe
Save the file in the Notebook and double click it once the download is completed to install the application.
Hope this helps....
Dec 20, 2008 | HP Pavilion dv4000 Notebook
Cit200
Adjusting the volume of the caller's voice
You can increase or decrease the volume of a caller's voice during a call. There are 5 volume levels for selection.
To adjust the volume, during a call: While the phone is off hook (i.e. dial tone can be heard), press Up or Down.
The display shows the current volume level. Press Up or Down again to adjust the volume.
Still can't find the most comfortable level?
Besides adjusting the volume on the handset, you might also need to adjust the volume on your PC in order to set the speaker to the most comfortable
volume.
To set your handset's ringing melodies and volume:
1. Press MENU.
2. Press Up or Down to select SOUNDS. Press OK.
3. Press Up or Down to select HANDSET. Press OK.
4. Press Left or Right to change the volume level. Press Down.
5. Press Left or Right to select the external melody. Press Down.
6. Press Left or Right to select the internal melody. Press OK to confirm when finished.
Nov 01, 2008 | Linksys CIT200 IP Wireless Phone
SanDisk Sansa View 8GB MP3 Player - Black Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
