Question about Dell Computers & Internet
What is yooton?
Have no discription
1998 plymouth voyager; when driving it sounds like racing in the indy 500, the vehiclle SOUNDS like its running at a high rate. But it is going a normal speed limit. dtc code is p0700; p1788; p0743. any...
According to the manual
P0700 = EATX Controller DTC Present
Discription= An automatic transmission input DTC has been set in the transmission controller.
P1733 no listing in manual
P0743 =Torque Converter Clutch Soleniod/Trans Relay Circuits
Discription= An open or shorted condition detected in the torque converter part throttle unlock solenoid control circuit (3 speed auto RH trans. only).
hope this helps
Dec 20, 2010 | 1998 Plymouth Voyager
What's causing a '97 plymouth voyager minivan to get P0134 & P0401 diagnostic code faults with dash 'checklight' for service?
P0134= Right Rear (or just) Upstream O2S Stays at Center
Discription=Neither rich or lean condition detected from the oxygen sensor.
P0401 =EGR System Failure
Discription= Required change in air/fuel ratio not detected during diagnostic test.
hope this helps
Dec 14, 2010 | 1997 Plymouth Voyager
Hard to start after shutting off
Please Try to be More Spacific as to "HARD START" Problem such as ,Does it turn oveer NORMALY but takes too Long to Start , Does Engine CRANK Slowly, Does it ACT like it WANTS to Start But will not Start Quickly ? This will Enable us to Give you a More Precise Answer, NOTE:: Possible Areas to give Attention to Given Your Discription, TUNE UP, >(Secondary Ignition Parts OLD) FUEL FILTER while Running Accumilating Debris then Upon Restart Not Allowing Proper Fuel VOLUME to Fuel Rail. Hope this Helps, If so Please Reflect this By Rating Me GOOD I thank you In Advance, But at the Same time I also Stress that You Would in the Future give a More DETAILED SYMPTOM Discription. Have a Good Easter Weekend !
Apr 04, 2010 | 2007 GMC Acadia SLE
I need fanuc ot cnc parameter discription for 900 to 940
The parameters 900 to 940 are different for each type of machine. You need to specify the control
Mar 30, 2010 | Computers & Internet
How can i hide product discriptions, in my ebay
you need to list the item under private auction, once the buyer provided you feedback the only thing that will appear is the feedback and the item number.
if you are the buyer, you can make your feedback private.
Nov 01, 2009 | eBay Auctions
How to change column in tally
change the portrait form of paper setting to landscape
Dec 17, 2008 | Tally T2250 Matrix Printer
Unable to brew.
if the temp lights are flashing a tru 5x's The temp sensor may be loose on the front control board. Also check the blue wire as well as the black wire that leads to the heater relay on the front board for melting at the relay.. Als be sure to check if you have any other light flash codes.. NOTE:.. You can get these code discriptions by removing the lid(one screw) and looking on the underside for a discription of the codes and the errors
Robb
Dec 05, 2008 | Bunn CDBCP35 Automatic Brewer with 1...
Need P/N and or discription
Part description = antenna isolater
available at Sanyo / Fisher Parts in Studio City,Ca.USA
AKA SFS Corp Call Information for Phone #
Or Partstore.com.........Phone # 1-866-925-7278
.................................................................................T.
Dec 12, 2007 | Televison & Video
Broken plastic sliding lug
Please send a picture, I cannot tell were it goes unless I know what it looks like, your discription is very discriptive, but please send a picture to the following e-mail address:
li199065@hotmail.com
Dec 01, 2007 | Breville CT20 Retro Classic 2-Slice...
Computers & Internet Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
