No cool air only hot air in my truck ...:( - Heating & Cooling
    New Friend:
    Problem Solver:
  • 8 Answers
Sounds like a bad compressor. Locate your compressor and see if it engages when you turn on A/C Should be in line with your serpentine belt. If that is not it. See if you are leaking refrigerant
Posted on Apr 26, 2013
02 ford explorer 4.0 overheating and suddenly blowing cold air, then hot again while engine runs cool but not long
Most likely you have air trapped in your engine, particularly in the heater loop. You need to properly bleed the air out of your radiator cooling system. The hot and cold blasts of air coming from first hot water followed by air.
Read up on how to bleed air out of your radiator system. Some systems are very difficult to bleed.
If after doing a good bleed of the radiator system the problem returns, you may have a bad head gasket or other leak in your cooling system which is injecting air into the cooling system (radiator/water cooling system).
Aug 12, 2014 | 2002 Ford Explorer
Car gets hot when Idle
You might check your cooling fan at the radiator; it may not be running. If it's not, track it down (fuse or thermal switch) and fix it!
Aug 07, 2014 | 2007 Suzuki XL7 AWD
The fan blower, even after changing it to cool -giving hot air
i would think the vent direction control isn't moving the heater box vent , stuck in the open position so only hot air from the engine ,strip out the control panel a check that the direction control cable is connected both ends ,
May 07, 2014 | 1999 Toyota Avalon
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
Cool air coming from the vents in the front but hot air coming from the back. What do I do to stop the hot air so that the room will cool down?
The hot air is a product of the cooling.... if you stop that then the unit will not cool!!!
You need to buy an exhaust kit to vent the hot air outside so that it will cool the room.
Otherwise it is just what is called a spot cooler or in other words you are cool if you sit in front of it, but it actually will make the overall room temp. hotter!!
heatman101
Jul 04, 2011 | Haier CPRB09XC7 Portable Air Conditioner
Hot air blows but cools down in 15-20 seconds.
You likely have a restriction in the heater coolant hose circuit - perhaps a coolant control valve not fully opening, or a kinked hose.
Insufficient coolant volume is flowing to keep the heater core hot.
Try back flushing the heater core system with a garden hose to check flow.
Nov 13, 2009 | 2003 Audi A4 Cabriolet
Air conditioning blowing only highest setting but HOT air
Sounds like your freon has leaked out and your heater blower resistor is burned out. Deffinitly take this to the dealer.
May 20, 2009 | 2001 Honda Odyssey
Heaterblows cool air my temp gauge showing truck is overheating
change the thermostate and gasket after you change it let the truck heat up then cool then refill the radiator again after the thermostate opens do not open the radiaator with the truck hot or the upper hose hard
Dec 10, 2008 | 1992 Ford Explorer
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
