Question about Gateway Computers & Internet
My gateway desktop will not shut down and stay off,it comes back on,then its off,on,off,on till i un plug then wait 15 to 20 mins befor i plug back in
  • 179 Answers
Sounds like a stuck power button or sticking power button. Compressed air usually will get it unstuck.
Posted on Jun 29, 2014
devildox
  • 40 Answers
SOURCE: My Acer Aspire AST180 shuts down with no warning
Sounds like you have a faulty power supply. The internal parts of your pc produce alot of heat, and if a part is heating up, then it will cause your pc to shut off.
With you saying that unplugging it , and then waiting , and then it comes back on, it sounds like once some part has cooled off, then the pc works.
My bet would be your power supply. Do make sure however, that all your parts are still tight in their sockets.. ie processor, memory , etc. I saw a pc that shut off at random times because the heat sink didn't make good contact with the processor once in college. So you want to check those things.
Posted on Jun 23, 2008
siawolf
  • 749 Answers
SOURCE: hp pavilion desktop a220n
check the fan (top rear of the computer) , make sure it runs when you start the computer. if it is NOT running the power supply may be the cause.
also you may need to remove the case and inspect the fans inside. you shoulkd be able to remove a couple phillips head screws on the back of the computer and lift the cover off or at least the side making the guts of thhe computer visible.
once open , inspect all the fans and cables, especially the fan on the main board and the metal piece with fins undernieth it, this tends to collect dust causing the cpu below to overheat and shut down the syatem to protect itself. The number one cause of crashes is overheating.
look at these things to start and post your findings and we'll move on to another step.
Posted on Oct 23, 2008
  • 17 Answers
SOURCE: Balance Cp4401 Desktop
I've had the same problem.
It's likely that the fan is either not working or shuts off prematurely.
The simple solution, instead of buying and installing a new internal fan is to place the computer on its side and put a small electric clip-on fan directly over the vent. Turn on the clip-on fan and then start the computer; the clip-on fan should generate more than enough cooling so that the computer doesn't overhead.
Two notes:
The clip-on fans usually have the clip on the back of the fan so you can clip it to a bed headboard or to a small pole or shelf; the fan is about six inches across, and they sell at Target, Wal-Mart, Amazon.com, etc., for anywhere from $15 to $25, but you can usually buy them at Big Lots or similar stores for about $5 and you can sometimes find them at the Dollar stores.
You can use a larger fan, but a larger fan will generate too much wind. You want to use an electric clip-on fan and not a battery operated fan because a battery operated fan won't generate enough wind/cooling.
And, if the problem ends up being more than simply a cooling problem, you can at least use the clip-on fan later.
Let me know if this works.
XMinusOne@gmail.com
on buy a small clip-on fan and place the fan dire.
The simple solution, instead of buying a new
Posted on Dec 10, 2008
rasengan79
  • 138 Answers
SOURCE: my Gateway GT5654 desktop just quit in the middle
Based on my experience, the most probable cause of your problem is the RAM. Try Cleaning the RAM first by removing it from the slot, and rub the pins with a pencil eraser. As shown on the image below: 263dfab.jpg
Then re-install it to the motherboard. If problem persist, you may need to replace your RAM.
Note: If you have two RAMs on your pc, might as well clean them both, and then test each RAM to find out if either one of them or both are busted.
Posted on Sep 24, 2009
virtualhost
  • 2185 Answers
SOURCE: emachine t6420 suddenly shutting down after about
Check on the processor installed inside the computer's motherboard, it might be loosen and make sure it is properly locked. Also check for the fan. Make sure the cpu is properly ventilated to avoid overheating that might cause the shutdown.
Posted on Sep 28, 2009
When i go to shut down pc dest top it goes off but comes right back on and keeps doing this off &on till i unplug it
some pcs can be set as default actions.. make sure it is not locked on restart as a default action when you hit shutdown..
Apr 21, 2013 | Gateway Computers & Internet
POWER
Trouble is in main power supply and likely puffed up filter capacitors on that board---common issue in a lot of sets.
Let me know if you have questions.
Mar 13, 2012 | Panasonic Televison & Video
I had a power failure in my area. When power was restored my pc booted up ok but the monitor screen only stays visible as it should for about 3 seconds, then it goes black screen. I have powered...
Close windows down. Wait 15 - 20 mins, then power monitor up but NOT windows. Screeen should say "NO SIGNAL in centre. If t does not, wait five mins If still no display shut down and wait another 5 mins. Then start monitor un ANDt windows.. All should be OK now, If not shut EVERYTHING down and disconnect from mains ovrernight. (PC riouter/modem,,,, EVERYTHING . 12 hours later, re-connetc in THIS order - 1.) MONITOR 2.) PC 3) ROUTER/MODEM Should be OK now.
Aug 17, 2011 | Acer X193W LCD Monitor
Old Gateway system (Desktop), Celeron 800MHz. After being on for 30min to an hour, operating system quits. Monitor displays first "no input" then "power saving" and will indefinitely keep cycling between...
sounds like its an over heating issue,i would check the fans to make sure they are all working and clean.Check that the cpu has thermal paste and that it still good(if its stiff or crumbles when you take off the heatsink it needs to be replaced)also check the memory is seatted all the way in.
Sep 01, 2010 | Gateway (683728192730) Barebone
When i start my Dell 9400 up and it takes 10 mins to load to windows XP, , when the windows loading screen comes up the FANS go crazy. I then wait till i'm at the desktop at which point i immediately shut...
Your battery HAS to stay in if its not working which means the OS needs the extra power.
If your fans are going crazy then your laptop is overheating!!!
Contact Dell
Dec 30, 2009 | Dell Inspiron 9400 Notebook
IBookG4 shuts down un-expectantly w/ battery fully charged
your having an overheating problem its either your processor or your chipset inside the laptop..let it rest for a while put a cooler pad under your laptop while using it to prevent further damage..i suggest you backup all your data also before it crashes permanently..also bring it to your nearest mac service center...hope this helps
Aug 31, 2009 | Apple iBook G4 Mac Notebook
PLUGGED PRINTER INTO COMPUTER WITH USB... COMPUTER CANNOT COMMUNICATE WITH PRINTER...IT IS AN ESP 5 ALL IN ONE
Remove the USB and un-plug the printer. wait 5 mins.
Reboot, wait till your fully booted up, and at the desktop.
plug the printer in, switch it on,
Jack it to the Pc,( last job )
Press the F5 function key a few times to flush the Pc,
The computer should recognise the device
Making the " bing " noise.
If not, test the USB port with another device.
Should be good now
Regards
Richard.
Apr 23, 2009 | Kodak ESP 5 Printer
Gateway desktop 506gr power issue narrowed down?
That was pretty unclear.  Is there a kind of burning symptom that suggests a short to you?  It seems to me that what happened is that either there was a power outage and your system thus shut down...all you'd have to to would be hit the computer's power button to turn it back on...or a fan somewhere died and therefore the system won't power up until you replace or repair that.  At least get a vacuum in there and brush out the dust so you can work.
What happened when you got a simplified system that 'worked'?  Was the power supply's fan spinning, at least?  What's the green light on, anyhow?
Jul 31, 2008 | Gateway 506GR PC Desktop
I have a Gateway One Model GZ7220. When it powers down the fan starts once the power is off and runs continously. I don't think it ever runs when the Gateway One is on. Can you help?
Wow that is strange. When the power supply turns off there cant be any more power.
Are you sure you dont log off or go to stand by? My computer does that to. Since I reinstalled windows my cpu fan stays running and my 2 case fans. Just go to power options to adjust your standy by options.
Jun 12, 2008 | Gateway Computers & Internet
Gateway stays 10 min at BIOS splash screen
I would say there a minor corruption in your hard drive. How old is this computer?? May time to reformat it.
May 15, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
