Question about Canon PowerShot S80 Digital Camera
Camera got stuck
My canon powershot s80 camera fell down when it was on. Now it got stuck and not getting opened or closed. Whenever I try to shut and open the shutter, it is lighting up and displaying the name CANON and becoming blank and displaying E18.
Thank You.
    President:
  • 1,566 Answers
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Posted on Apr 06, 2010
I have a canon powershot sx100 IS the lens is
Here is a site that discusses things you can try to fix this for free. They do a much better job than I could, and they let you know the risks and steps to take, in order. Try this first, you might get lucky- they say 50% of stuck lenses or lens errors can be fixed.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Don't worry, this is a huge problem with extendable lenses, due to their construction with small, plastic gears that are easy to break with a bump or fall, or obstruction while extending.
Apr 18, 2010 | Canon PowerShot SX100 IS Digital Camera
The problem I am having with my Canon PowerShot S2 IS is the iris is staying closed. No matter what I do it just stays closed. What could have caused this? How would I fix this problem?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
As you own an S2, if you live in the US, recommend contacting Canon first as mentioned in the link. Although it's highly likely that you can quickly fix your camera with the techniques shown in the article, why not get professional free repair from Canon if it's offered? The Canon repair may help prevent this from happening again.
Jan 24, 2010 | Canon PowerShot S2 IS Digital Camera
Close up photography for canon S80
You can use your Canon s80 for close up photography. Turn your dial mode to SCN. It has a selection for digital macro. Check your users manual for further instruction.
Good Luck and I hope this helped!
Nov 13, 2009 | Canon PowerShot S80 Digital Camera
My Canon Power Shot A1100 IS camera fell and now
There is no DIY fix for this problem, and attempting a fix is likely to worsen the problem and cause the camera to shut down. Sorry, but your situation calls for professional repair.
Oct 31, 2009 | Canon PowerShot A1100 IS Digital Camera
Canon Powershot A 620
Check your owner / user manual. I had similar problem and it was caused by "Mode" and "Flash" settings.
Jul 23, 2009 | Canon PowerShot A620 Digital Camera
Canon Powershot A510 black screen when taking photos
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 20, 2009 | Canon PowerShot A510 Digital Camera
Powershot SD1000 automatically shuts down in Camera mode
In any mode that the camera will stay on, press the "Menu" button and navigate to the RESET option and try to reset the camera. See if this will get the camera to function properly.
Jun 11, 2009 | Canon PowerShot SD1000 Digital Camera
Canon powershot s80
Marcus, usually this is caused by some dirt or some parts of the lens mechanis may have been derailed due to impact or brakage.
what you want to do here is turn the camera on, and gently nudge the lens left to right or up and down.
if this did not work, you may also try to push the lens inwards or pull it out, just to check if the lens is stuck or the motor to make the lens go in and out is not operational anymore...
if you have more questions just lemme know
Sep 30, 2008 | Canon PowerShot S80 Digital Camera
Black LCD screen on canon powershot S5 IS
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Aug 11, 2008 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S80 Digital Camera Logo
231 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
