Question about Vehicle Parts & Accessories
Would like to know what that rubber tube goes to what it is for that is in the right rear panel of the trunk of my Nissan 2002 Altima 3.5
    Sergeant:
    Champion:
  • 255 Answers
It is a drain tube. it neds to be set bak into the slot to drain the water out the bottom.
Posted on Apr 21, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Water leak in trunk 2002 Thunderbird
It's not a drain tube,it's a vent tube for your battery since it's in your trunk,I have a 2004 lincoln ls with battery in the trunk,says we are suppose to use vented batteries,never had to replace mine,only had it for about 3 years,did replace the negative battery cable,my car is a ford product like your's.Here's a cool link about our trunk batteries.You should have the vent tube connected to your battery.Just went and looked at my battery,it is a Autozone brand and it has a vent tube on the battery,tube goes thru and is vented out the back where you can't see.If you have a leak then check your rubber around the trunk. 2002 Thunderbird Trunk
Jun 28, 2017 | Cars & Trucks
How to check why my car alarm in 2006 nissan altima is not working
If it aftermarket(bunch of wires and modules under the dash on the drivers side) remove it. If it is still factory it takes a scanner.
Dec 03, 2015 | Nissan Cars & Trucks
Procerure to replace wheel bearing assy 2004 nissan altima 4cyl
Go to YOU TUBE and put in replacing wheel bearing hubs for
nissan altima & watch
There is a lot to see even if on a different vehicle
I doubt you have the tools to do the job
Sep 19, 2012 | Nissan Altima Cars & Trucks
Where is the a/c drain plug in a 07 maxima?
your going to have to get the car in the air . there should be a small rubber tube passenger side right about where your feet would rest.somtimes you can use a coat hanger to clear the tube
Aug 31, 2012 | 2002 Nissan Altima
Is there a fuse for a 02 nissan altima trunk latch
If it doesn't even click, then maybe. My Nissan trunk latch needs lubricating or it doesn't open... Had to crawl into the trunk through the back seat hatch to open the emergency pull-cord. Twice.
Jan 07, 2012 | 2002 Nissan Altima
I just bought a 2002 Nissan Altima SL. The car is rebuilt to I expected some problems. The horn will not work and all the windows do not go down. Also, the check engine light, airbag light, and trunk light...
on multiple system failures the most common problem is usually a faulty ground, causing other systems to loop back throug a grounded circuit, like if the rear light ground is bad when you hit the brakes the voltage goes back through the park light circuit to the front park light which are grounded causing alll the light to go on to name one so go over all engine and body grounds first
Apr 12, 2011 | 2002 Nissan Altima
2005 NISSAN ALTIMA 2.5S THE TRUNK RELEASE BUTTON DOESN'T OPEN THE TRUNK,ANY IDEA WHY?
check in your glove box on left hand side.valet switch may have accidentally set.let me know how you make out!
Feb 12, 2011 | 2005 Nissan Altima
The seal of the trunk of my 93 Nissan Altima needs replacing.
its probaley a dealer item or you can try jc whitney
Aug 16, 2009 | 1993 Nissan Altima
Left rear splash shield 2002 Altima fell off
4 clips to the fender. 3 bolts to the body frame. the splash shield cover the tire.
Apr 23, 2009 | 2002 Nissan Altima
2005 altima fuel pump
The tank does not need to be dropped. There is a access panel either under the cushion of the rear seat or in the trunk. I have to replace the pump on my 02
Jan 31, 2009 | 2005 Nissan Altima
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
