Question about Vehicle Parts & Accessories
The 15amp fuse keeps blowing and we have figured out that its shorting out. Can anyone tell me what this fuse is for and where it is wired to cause I have no clue. It's the white wire with the green s
The 15amp fuse keeps blowing and we have figured out that its shorting out. Can anyone tell me what this fuse is for and where it is wired to cause I have no clue. It's the white wire with the green strip and brown dots and its the black wire with a red strip coming from the F1 fuse in on the inside fuse box. --1995 Geo Tracker--
    Sergeant:
    Champion:
  • 247 Answers
The fuse blew! wat is not working as a result?! most times the fuse box wil tel wat the fuse is 4. if not look it up in u r owners book.
Posted on Apr 21, 2013
  • Jessica Bobb Apr 21, 2013
    It's not allowing no spark as a result. And I don't have an owners manual.
  • Matt Tonning
    Matt Tonning Nov 29, 2013
    First --- Do you have a carbureted engine or fuel injected? If injected it could the main relay to the fuel pump. Check that before you pull the fuel pump. Fuel injected engine puts the pump in the tank. On the left kick panel wiring harness goes into body. The wires go to rear of vehicle. Find the pink wire w/black stripe then install a inline blade fuse holder and piggyback to ignition wire (power on) coming out of steering column white wire w/green stripe. This will turn on fuel pump when key is in on pos.
  • 30 Answers
Posted on Nov 29, 2013
    Problem Solver:
  • 13 Answers
When you take VPN service from a putative supplier, they assist you to get Debian VPN on your computer systems. A VPN service is compatible with an oversized range of operative systems like Windows 2000, Windows 7, Windows 8, Widows XP, Ubuntu, Fedora, Debian, CentOS, RedHat, Gentoo, Mac, Unix etc. to put in VPN Debian software system, users have to be compelled to transfer consumer software system on their computer systems provided by the VPN vender.
Posted on May 09, 2013
Eng cont1 fuse
fuses blow because of excess current draw. check for a short after the fuse . wire touching the earth or body / engine or melted on the exhaust
Dec 06, 2013 | 2000 Nissan Maxima
Fuse keeps blowing
Hi Anonymous, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and start tracking the wire from the power side of the switch, circuit breaker or the blown fuse receiver, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Jul 02, 2013 | Harley Davidson XL 1200 C Sportster Custom...
99 dodge no tail or dash lights keeps blowing fuses
the dash and tail lights are ran on the same fuse/curcit your shorting to ground somewhere along the lines. check for a broken bulb melted wiring or a broken wire
Aug 30, 2012 | 1999 Dodge Ram 2500 4WD
Hello and thanks for your time, I have a 92 0lds cutlass with over 170,000 miles at speeds of above 60 I start blowing fuses it started with turn right turn signal, I changed fuse it did it again, I...
what i think is happening is when you travel fast the wind and bumps are causing a wire to short and blow the fuses. a bad ground will cause this also. If you do not exceed 60 the fuses dont blow ? At times like these i do alot of hands on and visual checks of connections and grounds by wiggling them and having a helper listen for a fuse to pop and by touching that wire then you know that was the problem. If i don't have a helper i wait till dark and turn on car lights or blinker what ever seems to go out and i will wiggle wires in the dark looking for small sparks indicating a short.
Apr 03, 2011 | 1992 Oldsmobile Cutlass Ciera
99 vw jettal 2.0 gas fuse 29 15amp fuse keeps blowing-no spark unpluged coil and fuse keeps blowing. help please
Thats the fuse for the ECU, engine control module, and is a 15amp for gas 2.0. i would locate the ECU which is under the center of the plenum in the engine compartment and disconnect the long plug. Check for green discoloration on the multipin connector. Sometimes moisture will get in there and short some of the pins together. Leave ECU unplugged and replace the fuse. If it still blows cause is between the fuse and the ECU.
Dec 27, 2010 | 1999 Volkswagen Jetta
10 A radio fuse keeps blowing. Can you put a bigger fuse in.
Yes but not recommended you could try a 15 but wouldnt go more there is most likely a short causing this I would inspect the wires going to the stereo if it blows the 15amp fuse
Nov 30, 2010 | 2008 Ford Escape
I have a BMW F650 Gs 2003 model. Problem.... Resent 40k service done and now it keep blowing 15amp fuses. They ( the service people) have checked everything. can't find the short. It only blows fuses when...
Which 15Amp fuse blows?? Sounds like a pinched wire in the area of the headlight/instrument cluster. Remove the faux gas tank cover center section and maybe also remove battery. check in front of battery compartment for pinched wires etc.
I can offer more help if you post which fuse blows. I can look on wiring diagrams and tell you which items are powered from the fuse in question.
Sep 21, 2010 | BMW F 650 GS Motorcycles
1988 toyota cressida.is blowing a 15amp EFI fuse in the hood.
check wiring harness for injectors,and the injectors Short to ground in harness or shorted injector. common problem with injectors are shorts to ground.
Aug 24, 2009 | 1988 Toyota Cressida
My fuse for the radio keeps blowing out on my 2005 Corolla
Some thing in onr of those components is shorting and /or drawing to much current. If you can't figure out which then you will have to get a diag. The serp belt could not cause this. Look at the 12v plug-ins.
Jul 18, 2009 | 2003 Toyota Corolla
Vehicle Parts & Accessories Logo
1,054 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
