Question about HP Deskjet 450 wbt Printer
PAPER JAM EVERY 3 PAPERS GET JAMED WHEN PRINTING, THE PAPER IS FINE ITS NOT OVERLOADED, JUST THE RED LIGHT COMES ON A LOT SAYING PAPER JAMED, WHEN I PRESS THE LIGHT BUTTON THE PAPER COMES OUT WITH NO PROBLEMS BUT LOSES THE PRINTED DOCUMENT.
    Sergeant:
  • 191 Answers
Open the front door and remove inkl cartridge then check thr is not any paper jam .thn refix the inkmcartridge.
Posted on Mar 12, 2009
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
Printer repeatedly jams.
there would be little bits of paper jamed inside the printer, now wnen ever you tries to take a new print at that time the bits of paper blocks to come out..........just open the printer and clear off the papers
Jun 20, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
After printing a page, 2 red light signals show and doesn't print anymore until after certainparts of the copier were opened and then closed. When the swiych in turned on again, it copies only 1 and then...
1)check properly if there is no paper jam, make sure all jams have been removed
it this doesn't work
2) Remove the paper in the paper tray and replace with papers tha do not have folded edges
Make sure you are not using a paper that cannot run smoothly through the photocopier (too light or too hard)
3) Also check if some papers are stucked under the paper tray.
Apr 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
Frequent jam in Lexmark E232
This can happen a lot if you're using very light weight paper.  Also, if the paper is not flat it can jam up too.  Best thing you can do is get yourself some higher quality paper and keep it in a air tight tub after you open it.
Nov 22, 2008 | Lexmark E232 Laser Printer
Paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Nov 04, 2008 | Dell 948 All-In-One InkJet Printer
Paper jam
problem with teflon sheat and pressor roller.Please replace the boath items.
Aug 05, 2008 | HP LaserJet 1018 Printer
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Print light blinking
turn it off..let it set for 4 min..and then turn it on..try a test page first, though
May 10, 2008 | Brother HL-5240 Laser Printer
141 people viewed this question
Ben Johnson
