Question about Coffee Makers & Espresso Machines
Keurig special edition b60 prime problem? My keurig now has the prime message showing up. I have ran through all of keurigs trouble shooting and none of it has worked. The prime message will go away sometimes if I take off the reservoir, fill it back up and put it back on but as soon as it takes water in to heat it just starts draining all of the water out into the cup until it gets about halfway down in the reservoir and then the prime message comes back. Keurig has basically said they can't help fix it and I'm outside of my warranty. Any help would be appreciated!
    Problem Solver:
  • 14 Answers
You may want to try this.
Simply trying to clear the lines often will work. And as you will see from the many comments below, by far the most reliable way to get your Keurig brewer working again is the "Slap and Burp" method.
Here is how you do it.
First, unplug the brewer and remove both the water reservoir and drip tray.
Next, hold the brewer upside down over the sink and slap the base a few times. And I mean really slap it.
Now put everything back together and try brewing again. Most of the time this works with a couple of good slaps. If not, try it again.
And don't worry, there are no laws against giving your Keurig a good slapping!
Posted on Jun 13, 2013
2 Suggested Answers
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
Can not prime keurig b60, what to do
Return if prime is not working. No prime, no workee.
Jan 03, 2012 | Keurig Special Edition B60 Coffee Maker
The word "prime" shows up in the window and I
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101';
Sep 17, 2011 | Keurig Special Edition B60 Coffee Maker
Prime message comes on
heatman101
Sep 13, 2011 | Keurig Special Edition B60 Coffee Maker
My Keurig coffee maker says "prime" is that the same as descale?
heatman101-=-
Aug 13, 2011 | Keurig Special Edition B60 Coffee Maker
Keurig says Not Ready....does nothing....I have tried unplugging it.....pushed every button.....NOTHING!
heatman101';
Aug 01, 2011 | Keurig Special Edition B60 Coffee Maker
My Keurig is new and will not brew a full cup.
heatman101
Jul 31, 2011 | Keurig Special Edition B60 Coffee Maker
What does it mean when a message comes on the Keurig that says "Prime"
heatman101=-=-
Jul 06, 2011 | Keurig Special Edition B60 Coffee Maker
My b60 will not prime
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Apr 16, 2011 | Keurig Special Edition B60 Coffee Maker
My keurig b60 looses its prime do you know how to fix it?
The easiest way to to just leave the tank on once you get it primed and then fill it with a pichter...
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Mar 06, 2011 | Keurig Special Edition B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
56 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
