Question about Gateway Computers & Internet
When i go to shut down pc dest top it goes off but comes right back on and keeps doing this off &on till i unplug it
Runs good just can't shut down
    New Friend:
  • 30 Answers
Some pcs can be set as default actions.. make sure it is not locked on restart as a default action when you hit shutdown..
Posted on Apr 22, 2013
tom19511
  • 1601 Answers
SOURCE: going to sleep
check the RAM. Take it out and reseat. also see if it runs good in safe mode. if so then you need new video drivers.
Posted on Dec 02, 2007
quadrantmind
  • 14 Answers
SOURCE: Hp xw 6000, keeps shuuting down during initial boot up.
reseat ram if not i'd say to take 1 stick of ram at a time and start the computer with such might be a ram issue or run memtest 1.7 which can be downloaded here http://www.memtest86.com/ boot to cd once downloaded and burned to test ram
Posted on Mar 19, 2008
  • 108 Answers
SOURCE: ntvdm.exe
boot to safe-mode - goto start then run and type msconfig -
Within Msconfig you should see a startup tab. Look in there and remove or uncheck all that appear to be using ntvdm.exe
Also check in start, programs, startup, remove anything there as well.
Let me know if that does not help.
G'luck
Posted on Oct 24, 2008
  • 15 Answers
SOURCE: pc keeps randomly powering off & then back on.
Power supplies usually are culprits in random shut downs, but random start ups is a bit more complicated. You say that when you hold the power button, the computer won't power down. Perhaps you have a faulty switch? Make sure your PW switch cable is securely attached to the motherboard. But I'm leaning more toward a faulty switch or a short in the wires. Seems like a good place to start.
Posted on Sep 05, 2009
joecoolvette
  • 5660 Answers
SOURCE: my HP 2009m goes into sleep mode & shuts down
I just bought a 20 inch HP 2009m monitor about 2 months ago.
One of the functions within the monitor, is to go to 'Sleep'
The Sleep mode is to keep the monitor active, but using very little power.
(I always turn mine off when I'm finished with the computer. More longevity for the monitor, and less electricity used. With today's economy every little bit helps)
You can set a desired time for the monitor to go into Sleep mode, or you can disable this function. (Off)
Factory setting is supposed to be set to Off, to my understanding.
You can view what the Sleep setting is, while you are using your monitor. The monitor has on On-Screen menu.
(OSD. On-Screen Display)
To the left of the Power On button, (Lighted when the monitor is on), there are Four function buttons.
These are located right under the bottom edge of the monitor.
One is located right under where it states - Menu
One is located right under the combination speaker symbol, and Minus - symbol.
One is located right under the combination Source, and Plus + symbol
The last button is located right under the combination Auto/OK
When the On-Screen Menu is activated it, is a small window.
You will still be able to view around it.
However, you may find it best to write the following instructions down, as you may not be able to view them here, and also the On-Screen menu.
1) Press the Menu button up.
The On-Screen main menu will now be visible.
2) In the list given you want Management.
Use the Minus ( - ) speaker button, to move the highlight down to Management.
3) With Management highlighted press the Auto/OK button.
4) In the Management sub-menu where you are now, you want to choose - Sleep, in the list.
Use the Minus - button, and move the highlight down to Sleep.
5) With Sleep highlighted press the Auto/OK button.
6) In the Sleep sub-menu view across from Timer.
Is ON highlighted?
Plus is there a time set?
If you wish to turn the Timer off:
Use the Minus - button to highlight Timer.
Press the Auto/OK button.
Now press the Minus - button, and highlight OFF.
Press the Auto/OK button again.
Save and Return at the bottom of the list should now be highlighted.
This will take you back a screen, and you should now see Exit highlighted.
Your monitor is now set to have the Sleep mode function shut off.
Should like to hear the results of this.
Posted on Feb 18, 2010
Will not reset blue light keeps flashing
Instead of pressing the shut down button (on the top right) and then the shut down and ok; press the button and hold it till it goes black then reboots. I don't know if it will help but it's worth a try. :-)
Feb 03, 2014 | Samsung Galaxy Cell Phones
2005 Polaris Ranger shuts down when hot
Could be the coil pack going bad or fuel pump. Find the coil pack and spray water on the outside of it. Not a lot just a stream to keep it cool. It should be on top. Here is a video https://www.youtube.com/watch?v=woE4OIhCvAs
Dec 30, 2017 | Polaris ATV
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
My Acer Laptop battery shuts down completely at 40 - 30
Go to Power Options --> On the plan you are using select change plan settings --> Change advanced power settings --> Scroll down till you reach battery and click the + next to it to expand the settings --> Where it says Critical battery level and Critical battery action (on battery) make sure that the level is at 5% and the action is to hibernate. If it's set to do nothing, it will keep running until it's out of battery and completely shut off. Plugging the AC adapter would give it more power. If that isn't the problem, check your battery's connection and consider replacing the battery.
Nov 03, 2012 | Acer Aspire 5742G
Lost picture
Try unplugging everything and then plugging it back in. When my xbox had the "ring of fire" my brother asked me to fix it and I just unplugged and re plugged it worked and came back to life. (be careful that you either have the instuction menu for setup of you can remember where all the plugs go, otherwise you'll have to right down what goes where or else you may get confused and never be able to fix your poor television)
Mar 22, 2012 | Protron PLTV3250 32 in. LCD Television
How do i turn on the trio t2810c
Just called customer service about this. With the screen unlocked, press the button on the front and hold it down for 5-10 seconds until a power down window appears on the screen. Double tap the screen to turn off the player. Repeat to turn the player back on.
Dec 23, 2011 | Mach Speed Trio Audio Players & Recorders
My acer aspire 5315 shuts off suddenly and won't restart till it wants to. I replaced the battery, no difference....what's wrong?
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced
Oct 22, 2010 | Acer Computers & Internet
Cut out
rewire the subs-each sub you want in series=8 ohms per sub-then at the amp wire the two 8 ohm subs in parallel which brings the ohms back down to 4 ohms which is optimal for the amp and it shouldnt shut down on you any more-try that-good luck
May 30, 2009 | Kicker ZX400.1 Car Audio Amplifier
Amp keeps cutting off
Do you have heavy enough gauge wire supplying B+ to amp.Big amps draw a lot of current and require very heavy gauge wire. The longer the run the heavier the gauge needed.
Apr 20, 2009 | AudioBahn A8000T Car Audio Amplifier
KDS monitor screen goes blank.when you shut it off & turn it back on it goes blank again within a few seconds.
make sure all the cables are secure... by unplugging and re-plugging them back in. Does the monitor feel very hot in the back or on top? If so unplug the monitor and tip it upside down to make sure nothing metal fell inside.
Apr 30, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
