Question about Emerson SB350 13 in. TV/DVD Combo
Is there a specific solid state part known to make the fuse blow in model number sb350
I unplugged my TV last night, and when I plugged it back in and turned it on it squealed, and a 1 ohm resistor blew, and made a bright flash and loud noise now it wont turn on. after we replaced the 1 ohm resistor with a new one and we checked 220 microfarad electrolytic capacitors and they were both good. we also checked the 4 diodes near those capacitors, and they were good . when we plugged the set in the and this time the 4 amp fuse blew... now we are wondering if there is a high power semiconductor device known to fail in this particular model TV that could be cause the fuse to blow..
    Top Expert:
  • Emerson Master
  • 74,106 Answers
It sounds that there is some short circuit with its main power supply regulator circuit. A detailed check is necessary to locate the exact faulty component/s. If you are sound in electronics, you can do it by yourself. If not, contact any service technician. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you check the site in Timeslide option, which can be selected from the drop down list at the top left side of the display window, it will make search easy.
Posted on Apr 23, 2013
5 Suggested Answers
  • 163 Answers
SOURCE: Unit blows fuses
its a short in the power supply but ist realy care?, whats the price of this unit?...good luck
Posted on Aug 11, 2006
jomaru
  • 337 Answers
SOURCE: tv wont turn on
The sound can be called screaming from the power supply,it senses a short and creates a frequency you can hear,the set has a problem and it needs to be repaired,I will check the horizontal out put transistor for a short,sometimes it goes bad without a reason and sometimes the high voltage transformer is also bad and both have to be replaced but first the transistor only if it goes bad again then you replaced the transformer too.Seek assistance from a servicer if you are not too familiar with tv service,it can be dangerous.
Posted on Oct 02, 2006
  • 308 Answers
SOURCE: TV turns on and off by itself.
That Emerson was actually made by Funai, and you may have to contact them for service. Emerson used to be a good brand, but they seem to just want to sell or lease their name to any company that wants to use it. Generally speaking, if you're looking for consumer electronics, don't shop at a store whose name ends with Mart. Even though your set is over a year old, it would probably not be worthwhile repairing it. If you decide to try anyway, their telephone number is 1-800-242-7158.
Posted on Jan 30, 2007
SD Tech
  • 14553 Answers
SOURCE: Emerson EWC20D3 20 in. TV/DVD Combo what is that loud whining noise from the back
What happens in this case is a small transformer or the high voltage transformer vibrate hard enough to make that sound--not loose or bad but can cause the vibration.
I have seen in customer's homes where it was loud enough to chase cats right out of the room even in a large room.
Two ways to deal with this----with the set apart locate the part by ear or even probing with a plastic tool---when you press close to it, the sound will diminish or go away.
Believe it or not (in our shop) once located we use a hot glue gun to take the sound away---
usually if very loud it is the high voltage transformer on the main TV board (see photo of a typical one) not on the black part but on the iron like (it is a different material) core that looks like a U bolt.
it can irritate but poses no danger.
Posted on Mar 28, 2012
I unplugged my 42 inch vizio last night then I try to plug it back in and it won't come on not even the vizio sign in the front of the TV light comes on what can I do
Hi Anonymous,
The power supply board in your TV needs to be checked. Please open the back cover if you can, check the fuse, replace it with the same rating one if you find it blown. If the set works, enjoy viewing, if the fuse blows again, consult some local TV tech. Before opening the set please check the mains cord also.
Good luck.
May 17, 2016 | Vizio Televison & Video
HTC wont turn on
HTCs have a known power glitch that affects many of their model of phones. Unplug the phone. Hold down volume down, volume up and power. Do not let go. Plug in power. Hold those three buttons down for NO LESS THAN three minutes. You may see a flashing red light in the process. Once you see solid red, it is in a charging state. Allow it to charge for an hour or so and then attempt to power it up normally. You may want to get a quality replacement battery from eBay or a respected vendor, since chances are you other battery is toast. Li-Ion batteries don't like to sit in a drianed state for very long without loosing their mojo.
Mar 17, 2014 | Cell Phones
Blows fuse on back of amp as soon as i hit the power button on what should i be looking for that is causein this
Not very specific but you did say amp, (guitar maybe)so.....IF it blows fuses when turning on is a dead short. Capacitors or if solid state sounds like final audio output transistors. Open and do a visual. If I knew what it is I could help more.
Feb 21, 2013 | Music
I have sb350 tv for my kid and i lost the parental on the dvd it wont play them how do i reset it
You have listed it as an Emerson.
Google the brand/model number with the words owner manual and if that does not work try finding the customer service toll free number for whoever made it (brand)
Mar 15, 2012 | Emerson SB350 13 in. TV/DVD Combo
I have a panasonic TH-C42HD18. Last night a fuse in my fuse box flipped so I lost power to the tv. I reset the fuse (in the fuse box) but now My tv will not turn on. Everything else plugged in to that...
If you have no power light on TV ,then you must have a blowed Fuse on the power supply board.
Check Fuse and check board for Bad Capacitors they will be vented or swollen on Top.
1000uf 16v 2200uf 10v 3300uf 10v.
Jun 02, 2011 | Panasonic TH-C42HD18 42 in. Plasma TV
I have a 52"
Need model number and blink code at time of defect.
Feb 16, 2011 | Panasonic Televison & Video
TV just died...
Hi there!
The fuse may have blown. If so and you know how to check for a faulty fuse inside a TV, it may be worth a shot. Please unplug before opening and replace fuse with same value. If it blows again, you have to have it seen to by a repair technician. Good Luck, Regards, JUS004
Mar 24, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv died
It sounds like the high voltage transformer went bad, There is no fox for you to do unless you have experience and the knowledge to fix and repair solid state TV sets. Play it safe and call out a RCA service center to give you an estimate. Good Luck
Jun 21, 2007 | RCA F27242GY 27" TV
Will not turn on, but....
the arc when you plug it in is from the degause cirt operating, the fault sounds like at least a pwr supply repair $100, & or vertical + $50,and or horizontal + $150,If water is the reason.
Dec 06, 2006 | RCA 27F650T 27" TV
TV won't turn on
Unless you know Solid State Electronics, there is nothing you can do. At best, You could unplug the TV, remove the back cover, slide out the Circuit board, and check the fuses. They will be at the front of the Circuit board, left hand side. But in all likelihood, it is not just the fuses, the Power Regulator STR would also be short circuited (happens often in SONY TVs) and so it is best that a professional technician have a look.
Sep 26, 2006 | Sony KV-36FS17 36" TV
Emerson SB350 13 in. TV/DVD Combo Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
