Question about Keurig B60 Special Edition Brewing System B60
Keurig special edition b60 prime problem? - Keurig B60 Special Edition Brewing System B60
    Problem Solver:
  • 14 Answers
You may want to try this.
Simply trying to clear the lines often will work. And as you will see from the many comments below, by far the most reliable way to get your Keurig brewer working again is the "Slap and Burp" method.
Here is how you do it.
First, unplug the brewer and remove both the water reservoir and drip tray.
Next, hold the brewer upside down over the sink and slap the base a few times. And I mean really slap it.
Now put everything back together and try brewing again. Most of the time this works with a couple of good slaps. If not, try it again.
And don't worry, there are no laws against giving your Keurig a good slapping!
Posted on Jun 13, 2013
  • 4 Answers
SOURCE: Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Posted on Jan 06, 2008
SOURCE: New Keurig B60 stopped working!
I had the same issue. I now believe that there was some "vapor lock" type issue. Mine would say the same thing, and i could hear the pump running, but the water level was not changing in the reservoir. I unplugged it, removed the reservoir, let it cool, then tipped it on its back for a few minutes, then on each side. Truthfully I was trying to see if there was some kink in the tubing. Couldn't find a problem, so set it back up and it runs great again.
Posted on Jan 02, 2010
  • 28 Answers
SOURCE: My Keurig B60 (special edition) won't stay on.
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Posted on Feb 07, 2010
  • 10865 Answers
SOURCE: The brewcover on my Keurig B60 broke. Both screw
Hi. go to keurig.com/parts and order what u need. J.
Posted on Jul 25, 2010
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
Can not prime keurig b60, what to do
Return if prime is not working. No prime, no workee.
Jan 03, 2012 | Keurig Special Edition B60 Coffee Maker
Prime message comes on
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 13, 2011 | Keurig Special Edition B60 Coffee Maker
My B60 keeps on flashing not ready and non of the buttons works the only way to stop flashing is to pull the cord out!!! What should i do?
heatman101
Sep 08, 2011 | Keurig Special Edition B60 Coffee Maker
It says Prime and I have done everything from turning it off to changing the water.
heatman101
Aug 19, 2011 | Keurig Special Edition B60 Coffee Maker
My Keurig coffee maker says "prime" is that the same as descale?
heatman101-=-
Aug 13, 2011 | Keurig Special Edition B60 Coffee Maker
My Keurig is new and will not brew a full cup.
heatman101
Jul 31, 2011 | Keurig Special Edition B60 Coffee Maker
Lights on coffeecup pictures keep flashing
heatman101
Jul 06, 2011 | Keurig Special Edition B60 Coffee Maker
My b60 will not prime
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Apr 16, 2011 | Keurig Special Edition B60 Coffee Maker
My keurig b60 looses its prime do you know how to fix it?
The easiest way to to just leave the tank on once you get it primed and then fill it with a pichter...
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Mar 06, 2011 | Keurig Special Edition B60 Coffee Maker
Keurig B60 Special Edition Brewing System B60 Logo
114 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
