Question about Motorola Mobility RAZR V3c Cellular Phone
Motorola Razr Black
Hi, The sreen goes blank when i close the flip. If i keep the flip open then it is fine. Please let me know what should i do. Thanks, Neha
  • 28 Answers
Flex cable must be looked at. You will need someong with some experience to look at it.
Posted on Aug 05, 2007
SOURCE:
How do i turn the motorola V3 razor on?
Hi, turning on any mobile phone is as simple as what you know. Just flip open the phone and press on the red button by the right hand side of the phone for about 5 seconds and the phone will come up.
Take care
Mar 09, 2010 | Motorola Mobility RAZR V3m Cellular Phone
My screen just went blank
If u have a Razor (As shown in the picture), If the mini Screen Works(When you close the phone) then then make sure the push down button((Turns off the main screen when you flip the phone closed) is not pushed down while the phone is open.
Hope this helps.
Jul 01, 2009 | Motorola Mobility RAZR V3
MOTOROLA KRZR K1 SCREEN GOT BLANK (WHITE OR BLACK)
I believe you have a problem with the hinge of the flip where your wire that connects to the display opens up your screen. If you keep opening the flip and closing it slowly does the screen turn on and off??? If it does then you have a problem with the hinge like I said. If not then it could be just a software glitch where you need to reinstall the operating system.
Sep 24, 2017 | Motorola Mobility MOTOKRZR K1 Cellular...
Razor phone srceen goes blank after a few seconds
This is the Early signs of Failure! Just had to Upgrade my RAZR for the same Problem. Your Options are (1) Have it Repaired-Costs a LOT! (2) Upgrade to a New or Refurbed Razr. There are no other Solutions
Aug 09, 2008 | Motorola Mobility RAZR V3
Phone goes blank
The Flexcable need to be replaced on the phone.
Jul 21, 2008 | Motorola Mobility RAZR V3
Flip screen
you need to replace the flexcable on the phone
Jun 29, 2008 | Motorola Mobility RAZR V3
Motorola KRZR black screen
This URL explains that the blank screen is caused by a loose cable, includes instructions, and includes another URL that shows how to take the phone apart and re-seat the cable: http://www.howardforums.com/archive/topic/963501-1.html
I just fixed mine. The cable goes from the back of the phone (below the battery and SIM card) around the hinge and connects again on the flip-up part, under the screen. Re-seating at the main unit didn't fix it for me (dang), so I had to take off the cover on the flip-up part. Pretty hairy, but doable. You'll need TORX #5 and #6 screwdrivers.
I also saw where local repair shops will fix it for $75 (ouch), but that may be for a screen replacement--which is probably not needed. Opening and closing the phone is what causes the (tiny, flat) cable to need re-seating.
May 09, 2008 | Motorola Mobility RAZR V3
V3 outer screen
There's a tiny magnet in the top of the flip, near the hinge.. try taking a small magnet and hold it over the keypad near the hinge, and see if it doesn't think it's closed, if that magnet didn't get put back in the flip, then the phone won't know it's closed.
good luck!
Oct 26, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Problem
Try the phone while plugged in and see what happens.  If it works fine then it's probably the battery or the contacts to the battery.  I've had a problem with my razr that's similar to this.  My razr is on the keys light up when i press something but the screen is completely blank open and closed and all the buttons work.  Best thing to try is leave out with battery and sim card out and it might start working again.  However if it is only 2 months old it should still be covered under warranty.
Oct 17, 2007 | Motorola Mobility RAZR V3
HELP!! my hot pink razr v3 has a red line constantly in the middle of the internal sreen..
take this to your provider to have fixed the sceern has broke in either a cable losse or a crack but thell fix it.
Sep 03, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
46 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
