Question about Nikon Coolpix 4500 Digital Camera
Nikon Coolpix 4500 broken on/off switch
Dismantled part of camera and found broken bit inside the on/off switch. Needs new rotating switch. Seems like the body section where the strap connects has to be replaced. Is this an easy enough job for me to do if I can get replacement bits or butcher another camera? Hope you can help. Thanks.
  • Anonymous Apr 22, 2009
    ditto
SOURCE: Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Posted on Mar 26, 2008
SOURCE: Coolpix 4500 lcd screen replacement
I have a lcd I just bought for L10 and it is the wrong one. It is for a 4200. If interested email me at theetrader@hotmail.com
Posted on Jun 04, 2008
  • 64 Answers
SOURCE: Nikon 4500 Coolpix
If u tried to hold up a 1000 lb weight what do u think would happen???
Well putting 12V into a 4V spicket will do the same thing.
Posted on Dec 08, 2008
  • 6 Answers
SOURCE: Replacing the battery door on a Nikon CoolPix 4600
Call 3104148107 This is the Nikon Parts line, be warned it will probably take as long as 30-45 minutes of old time to get to a person.
Once you can get to a person, give them the camera model and describe the problem. They just sold me a replacement battery door for $9.95 + $6 dollars shipping and handling.
The rep was so nice he even printed out the device design blow up, and the relevant section of the manual, so I could see the step by step with out having to purchase the full blown repair manual, which runs $83.
Posted on Sep 02, 2009
dlundmark
  • 797 Answers
SOURCE: Nikon Coolpix S210 lcd broken - need step by step instructions
Most cameras are not that hard, if you are careful and willing to make notes of where each screw came from.
Be sure to get the correct screwdriver to fit the screws correctly and use enough pressure directly to loosen each screw...this is quite important, because if you strip the screw's head, it can be messy.
Most LCD screens are directly under the back cover, and can be replaced usually, once the back is off, remove three or four screw which will hold the LCD frame on. Once that is loosened, then you can carefully remove the screen and see if you need to remove anything else before loosening the cable plug. Take care here, because there are a few different ways these cables may be connected. Some are simply pushed into a connector. Some have a socket which has locks which must be loosened to remove the cable. These little sliding plug connectors are delicate, so you must take it slow and not rush the job. Some of these fold up to loosen, some simply slide away a bit to loosen the plug lock.
Most anyone who has done any delicate work on anything electronic will understand what I am talking about here.
A repair manual may be able to be downloaded for free, but you may have to be a member (usually free) in order to download manuals. Some may charge a small fee for the pdf file.
Hope it all works okay.
Posted on Sep 11, 2009
Testimonial: "Thanks for the suggestions and help. It worked."
My 4500 needs cleaning -- rotating joint feels gritty. who cah repair and cliean
Their will be a small fee but nikon can fix it and mail it back to you
Jun 12, 2014 | Nikon Coolpix 4500 Digital Camera
Memory card is write protected as my nikon coolpix screen shows and no any option is getting for picture click
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 24, 2012 | Nikon Coolpix 4500 Digital Camera
New to photography. Coolpix s3000. shooting in auto mode. When taking a photo of someone and they move just a little bit, say their hand it blurs. Is this normal for this camera. I have an older Nikon and...
Hi, With auto mode on that camera that is normal I've found. Auto mode on that camera seems to leave the shutter open just long enough to capture the tiniest bit of motion. If you're looking to shoot in a mode where that doesn't happen I suggest shooting in sports mode or kids mode.
May 13, 2011 | Nikon Coolpix S3000 Digital Camera
Broken Nikon L20 LCD Screen
door where the battery goes broke
May 29, 2009 | Nikon COOLPIX L20 Digital Camera
"memory card is write protected"?? but it's not the memory card!
It's not the camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 13, 2009 | Nikon Coolpix 4500 Digital Camera
Nikon 4500 Coolpix
Nov 09, 2008 | Nikon Coolpix 4500 Digital Camera
Nikon coolpix 4500 uv lens
I bought a 4 lens kit - I think from Amazon. It was a long time ago.
The size is 28mm.
yes, here it is
http://www.amazon.com/Nikon-28mm-Filter-Set-Coolpix/dp/B0000521B9
Oct 14, 2008 | Nikon Coolpix 4500 Digital Camera
Coolpix 4300 needs driver & update for vista
this solution was originally written by a fellow expert dauphine
You can download PictureProject software from this address: http://chsv-soft.nikon-image.com/jpn/software/win/S-P2____-175WU-JPNJP.exe
That is the only Nikon software that supports Vista since your camera is "outdated".
Here is a quote from Nikon site:
  • We had released a Windows Vista-compatible version of PictureProject, v1.7.5, for use with the models listed below, and all models that followed. PTP (models supporting the PTP protocol) and Mass storage USB transfer options can be used for camera connection. However, the camera's transfer button can not be used to transfer pictures over a PTP connection. Set the USB transfer option to Mass storage to enable the camera's transfer button.
    Currently, the new Nikon Transfer and View NX will replace Picture Project as our new Image Transfer and Browser applications. These applications support the same Nikon products as Picture Project.
COOLPIX P4, COOLPIX P3, COOLPIX P2, COOLPIX P1,COOLPIX S10, COOLPIX S9, COOLPIX S8, COOLPIX S7c, COOLPIX S7, COOLPIX S6, COOLPIX S5, COOLPIX S4, COOLPIX S3, COOLPIX S2, COOLPIX S1,COOLPIX L6, COOLPIX L5, COOLPIX L4, COOLPIX L3, COOLPIX L2, COOLPIX L1/L101,COOLPIX SQ, COOLPIX 8800, COOLPIX 8700, COOLPIX 8400, COOLPIX 7900, COOLPIX 7600,COOLPIX 5900, COOLPIX 5700, COOLPIX 5600, COOLPIX 5400, COOLPIX 5200, (COOLPIX 5100), COOLPIX 5000, COOLPIX 4800, (COOLPIX 4600), COOLPIX 4500, COOLPIX 4300, COOLPIX 4200, COOLPIX 4100, COOLPIX 3700, COOLPIX 3500, COOLPIX 3200, COOLPIX 3100, COOLPIX 2500, COOLPIX 2200, COOLPIX 2100, COOLPIX 2000,COOLPIX 995, COOLPIX 885, COOLPIX 775.We do not plan to offer compatibility for COOLPIX 990 OR COOLPIX 880 connection to a computer with Windows Vista preinstalled. Use a card reader or card slot to transfer images.
Jun 15, 2008 | Nikon COOLPIX S5 Digital Camera
Apr 20, 2008 | Nikon Coolpix 4300 Digital Camera
Oct 31, 2007 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix 4500 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
