Question about Car Audio & Video
Owners manual for my kenwood kgc-9400 graphic eq i want to inst
Owners manual for my kenwood kgc-9400 graphic equalizer
  • 102 Answers
Download from Kenwood's website
Posted on Mar 12, 2009
How to hook up a equalizer
i believe you need to be running an aftermarket amplifier to use this E.Q. does it only have RCA inputs and outputs on the back of it? if it does, you'll need to run the rca's out of the radio into the E.Q. then run the rca out's from the E.Q. to the inputs of your amplifier. and of course there's probably a constant 12v, a switched 12v, and a ground you'll have to wire up.
Feb 17, 2010 | Kenwood KGC-4042A 5-Band Car Equalizer
Power unit on test for Kenwood kgc 7043
should not need the head unit.open up unit and start testing continuity along wire an board.possible break in connection.
Feb 24, 2009 | Kenwood Car Audio & Video
Best settings on a 13 band eq for rock and r&b
THAT IS BASE ON HOW YOUR SYSTEM IS SET UP MY FRIEND ADJUSTING ALL THOSE SETTING WONT GIVE YOU MORE BASS
Feb 11, 2009 | Kenwood KGC-9044 11-Band Car Equalizer
CONNECTING
you can do it passive. no idea with your ampli, but if it does have a bridge then you can hook your eq there, series. if it doesn't have then via tape monitor 2 of your kenwood.
onkyo recvr tape 2 record to - kenwood eq in
onyo recvr tape 2 playback - kenwood eq out
that's all. if you want your eq to be active, then switch your reciever to tape2, all selected input in your reciever will by pass through your eq then back to kenwood. you dont have a function for tape 2 input then but your eq will have an extra input for tape, that you can use for your second tape, it will be active only if your reciever is set to tape 2. i hope you got it right.
post back if you got it done
red
Feb 10, 2008 | Audio Players & Recorders
Power connection
Theres supposed to be a harness that plugs into that connector. It will have the international color standard wires. Contact a kenwood dealer to get the harness.
Sep 14, 2007 | Kenwood KGC-6042A 9-Band Car Equalizer
HELP installing kenwood KGC 9044
You will only use the front pre outs from the deck to plug into the only available input on the EQ. You will loose fading and subwoofer controls from the deck which is the main problem when using an eq. Then go from the eq to each of the 3 corresponding amplifiers (front, rear, sub). You will then use the eq as your control for ading front to back and sub control. Im sure by now you have it figured out anyway but if you need help, let me know. Be sure to leave good feedback so and get paid!!!!$$$
Jul 25, 2007 | Kenwood KGC-9044 11-Band Car Equalizer
(How To?) installing kenwood KGC 9044
You'll have to use your choice of either the front outputs or rear outputs to plug into the eq. Most equalizers I've ever seen only accept 2 channels of input, then give anything from 2 to 6 channels of output, depending on the eq.
Which wire is power and ground
generally red is the ignition wire, black is ground, orange is 12+ all the time, a yellow could be the same....it would be more helpfull if you would give the model number of the eq
Jul 13, 2007 | Kenwood KGC-4042A 5-Band Car Equalizer
Car Audio & Video Logo
1,015 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
