Question edited for clarity, wrong type of 'skill' > 'Skil'.
Question moved from 'Laser Airlines'!
Model Numbers are needed for definitive answer, but just generic descriptions given so generic answers supplied.
Try touching the positive and the negative battery cables together and then hooking them back on battery then this is important 1-- unlock with key (if not locked lock it then unlock all doors with key leave doors open and put key in try to start leave in the on position for ten mins until light stops blinking then try starting it again if it don't start then leave key in on position wait ten more mins and start truck as always hope this helps good luck
you have to do that cycle 3 times,battery needs to fully charged.
Hood to stay closed,doors also(roll down the drivers window)
Kill the DRL headlights if possible(try putting the E-brake on)
Crank and leave key on,10 min or till light goes out,then key off,,no need to wait 5 min here,crank again.leave key on,,,,,3 times.
By the way,disconnecting the battery in that vehicle will not do anything like clear codes or memory,may need the radio code in the owners manual also.
Thats most likely cause there was a short in the alternator, regulator or rectifier charging circuit.. You will need to have this Professionally looked at but be prepared to purchase a new alternator and the wiring for it.
Although I am not completely familiar with the internals of the NERF NIGHTFINDER I have a good idea what is wrong.
Sometimes factories screw up, etc...
Lemme get to the point.
The circuit operating your light (if you don't know what that is look it up and find out) is probably not connected. Open up the laser and look online at what the internals look like. Make sure that the circuit is complete.
That's all, email me at [email protected] for more info on modding and nerf guns.
