Question about HP Officejet Pro L7380 Laser Printer
HP Office jet Pro L7380 will not pick up paper
The printer will not pickup paper, and displays a message that the printer is out of paper.
I have checked for jams - seems ok.
The support that HP provides is pathetic. They class this printer as a
throw-away-item, even though I paid $400 for it.
Can you help?
Regards,
Ashley
  • ashmoo Mar 13, 2009
    Thanks for your help.
    I have already fanned the paper before loading it into the printer.
    However, I did notice that the wheel does not drop down to pick up the sheet of paper when printing. What would cause this?
    Regards,
    Ashley
  • HP Master
  • 419 Answers
Paper feed problems are very common with HP officejet printers but don't panic...
Few things to try..
1. Check that when the printer tries to feed paper the wheel is dropping down and making contact with the paper.
2. Make sure you have not set the paper guides so the paper is too tightly held... try loosening them
3. Watch this little video on how to fan-apart paper and try doing this to get some air in between the paper sheets.. This often resolves many of the problems.
4. Try changing the paper for something a bit coarser or even cheaper as HP printers can be a bit "Fussy" about the paper they will feed best...
Hope that helps...
Posted on Mar 13, 2009
  • Martin Smallridge
    Martin Smallridge Mar 13, 2009
    There are a series of cog wheels that turn a mechanism which drops the wheel and also turns it... If that's not working it could be something as simple as a drive band (basically a rubber band) that's broken or popped off but unfortunately I don't have an L7380 (or a service manual) to be able to check where or if this would be the case.
    You could try locating a repair shop near you that has experience of HP printers but overall I suspect an official one would charge a fair amount.
    If it comes down to "disposal" my advice is to put it on eBay or similar as spares & repair as that can often bring you a small amount of cash back... Not ideal but it's better than landfill.
    Sorry I can't help more.
I've got a similar problem but in my case the pickup roller drops correctly if I am using the copy function (ie scan then print). Could this be a driver related issue (or some darn windows patch)?
Chris
Posted on Jul 14, 2009
Hullo, my laser jet Pinter does not pick paper. It continuously Shows "printing" on the display screen for 40 seconds but does not pick paper. Even the Printer Self test behaves in a similar way. Please...
Does it make a noise as if its doing anything? Most common thing is the pickup roller has worn out, they're really easy to replace, you can just search google or ebay for - pickup roller and whatever the model number of your printer is to find it
Jan 15, 2014 | HP LaserJet P2055d Printer
Hp officejet pro l7780 all in one printer, Cleaned the pick up roller still not picking up paper
The pick up roller may be worn and in need of replacement. The slight grinding noise is the pickup roller trying to work but slipping
Oct 30, 2012 | HP Office Equipment & Supplies
Hp office jet l7680, paper jam, however no visible paper remaining, jam indicator still flashing.
If the printer shows ready and after you send the print or copy job it gives you paper jam, then the problem is with the pickup roller.
Let me know and I will help you further.
Oct 13, 2011 | HP Officejet Pro L7680 All-In-One Printer
I have a HP Office Jet 6500. Can you tell me how to fax more than one page from the glass without redialing. After my first page is sent, can a prompt be set up asking if I have another page?
Put the documents you want to fax in the tray.Dial the fax number.After that the printer will scan the docs first and the send via memory.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 17, 2010 | HP Officejet Pro L7380 Laser Printer
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
steps:
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
I have hp officejet pro L7380 printer, but it print head has always problem. hoe to repair it at home>
Hello sir; It cost too much to repaire than to buy a new one, don't even think about it.
Aug 28, 2009 | HP Officejet Pro L7380 Laser Printer
Clear Paper Jam, then Press OK
Have you checked the access door in the rear of the machine?
Jan 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Installation software for HP officejet Pro L7380
its easy..simply go to hp or compaq support and they have volumes of drivers and free updates
Dec 30, 2008 | HP Officejet Pro L7380 Laser Printer
No Paper Pickup error
Check all this ---------
1.check the paper pickup roller may be its not functioning
proper.
2.check the paper pickup sensor(clean this)
3.check the paper pickup tray for proper work.
4.check the gear of paper pickup.
thanks
Mar 20, 2008 | HP LaserJet 3390 All-in-One Multifunction...
HP Officejet Pro L7380 Laser Printer Logo
509 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
