Question about Maytag Maxima EcoConserve Series MHW6000X 27" Front-Load Washer with 5.0 cu. ft. Capacity, 11
I have a maytag maxima
Door lock
How do I unlock the door on the maytag maxima front load washer
Jay, if you're sure there is no water in the drum, unplug the machine and pull it away from the wall enough that you can unfasten the two screws in the upper corners of the back (they are likely T-20 screws). When these screws are removed, you can pull the top of the cabinet back and lift it off the machine.
Once the top is removed (and making sure the machine is unplugged), you can look down the right front and see the door lock mechanism. On that part, you should see a round plastic ring. Pulling that ring will manually release the door lock.
Feb 01, 2015 | Maytag Washing Machines
Maytag Maxima Front Load Washer. F01 / E02 error codes. Power on, kicks off cycle, locks door, but will not call for water.
Tip the machine up & look inside up high, you
should find a bag with the diagnostic service
manual & it has the codes
Sep 04, 2013 | Washing Machines
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
2004 maxima rear door locks stay locked after i
MOST LIKELY ATHERES A CHILD PROOF SWITCH ON ONE ORBOTH DOORS ON THE PART THAT SHUTS
Jul 20, 2010 | 2005 Nissan Maxima
We just bought a 2006 nissan maxima should the
the doors sould lock when you start t drive, they will not unlock when you stop, but the design of the inside door handle will unlock the door when is opened from the inside.
Jun 24, 2009 | 1993 Nissan Maxima
Power door locks '90 nissan maxima
Try Prying Them Up If Ones Disconnected On Some Cars All The Buttons On Any Other Door Will Not Operate. You Also May Want To Check The Fuses.+
Nov 25, 2008 | 1990 Nissan Maxima
Maytag Maxima EcoConserve Series MHW6000X 27" Front-Load Washer with 5.0 cu. ft. Capacity, 11 Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
