Question about Hardware & Accessories
Rainbird e6c shows 5 ERR
Rainbird troubleshooting
It could be not enough water pressure, dirt on the shaft or it is worn out assuming the parts are all there. They are not very expensive you might just want to buy a new one.
Aug 10, 2014 | Rainbird Rain Bird Maxi Paw Ag-5 Inground...
Check to see what the codes refer to. It could be a zone solenoid going bad.
Jul 13, 2014 | Garden
Rainbird esp6si controller not working
Moisture could be getting in and shorting this unit out.
Jan 06, 2018 | Garden
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Rainbird controller lock up
You need to replace your controller.
Jul 05, 2009 | Rain Bird Hardware & Accessories
Hardware & Accessories Logo
16 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
