Question about Electric Mobility Health & Beauty
KEY LOCK HIGHLIGHTED ON CONTROL PANEL .... the key symbol on control panel is flashing red and wheelchair panel is not working? How can I unlock it?
    Sergeant:
  • 317 Answers
What is your controller model?
Posted on Jun 15, 2013
  • Anonymous May 06, 2016
    Invacare acs
  • 32 Answers
SOURCE: wheelchair problem
sounds like you might have locked joystick by mistake. Try pressing and holding down the on/off switch for 5 seconds.
Posted on Jul 12, 2009
  • 175 Answers
SOURCE: working on a pride wheelchair that i just put (2)
First, make sure that the motors are both engaged and not in freewheel, and that the charger is unplugged. If it is a constant flash without pause, this is usually an indication that the joystick is "out of neutral", a problem caused by hitting running the joystick handle under a table, for instance, of moisture in the joystick itself. If it is a series of flashes, like 4, pause repeat, then you have a fault somewhere else in the chair. Here's a link to the flash codes for your controller. http://www.dynamiccontrols.com/index.cfm/3,73,237/dna-flash-codes-0307.pdf The flashes, types and manner of flash need to be better described in your posting. Good luck.
Posted on Jan 08, 2010
  • 175 Answers
SOURCE: The electric wheelchair is flashing the locked sym...
Turn on chair, move joystick forward till it beeps, then all the way back till it beeps, and then let go of joystick, it should fire up.
Posted on May 23, 2010
  • 692 Answers
SOURCE: acs typh. invacare electric wheelchair, red light
Press the power button on then press the horn button twice before ten seconds. this should unlock the joystick
Posted on Aug 17, 2010
guyster7148
  • 192 Answers
SOURCE: Flashing green light on the
You more that likely have a problem with the KILL switch. There are several on these creatures, but I am sure we can get to the right one.... First, check under the seat, make sure that there are NO loose connections, this can kill it right fast. Then check your gas and brake lines and look for kinds, if there is one then the machine will die instantly. All of these are for the safety for the rider... Take care, and please VOTE if you got any help.... Guy :)
Posted on Sep 13, 2010
A key symbol is showing. How do we unlock
Hello. Look on the control panel for a button(or set of buttons) that are usually pressed for 4-5 seconds. The button(s) will have a lock symbol or the word "lock" beneath it. You press and hold the button(s) until the lock symbol goes dark. That tells you the lock has been disabled.
Nov 03, 2015 | Ovens
How do I cancel the control lock
It would help if you gave the brand and model number of your dishwasher, but the answer is basically the same. Look carefully at your dishwasher control panel. You probably have a little lock symbol that is lit up (or a light inside the symbol is lit). And usually this lock symbol is located near (usually above) a button that is usually used for another purpose. Most often this is the Heated-Dry key or button. Press and hold this key for 3 to 5 seconds until the lock symbol light goes out. And it's just that easy! But if you press the key, and nothing happens, then you may have a bad control console that will have to be replaced.
Feb 25, 2015 | Dishwashers
WHAT DOES CONTROL LOCK ON A GE GAS DRYER MEAN
push the lock/unlock button for several seconds to unlock the control panel. on some it says lock on some it shows a key
Jan 31, 2015 | GE Dryers
Bottom oven stopped working there is a key symbol showing on the panel what is wrong ?
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock.
Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Oct 04, 2014 | Bosch HBL 5056 Electric Double Oven
Kenmore ultra wash machine won't run even with indicator lights on. Symbol on machine says Lock on
You have the control-lock function turned on. There should be a key located near (above or below) the lighted lock symbol. Usually, it's the Heated Dry button. Whatever it is, press and hold that key for 5 seconds. That should unlock your dishwasher and you can now use it normally.
Jul 15, 2014 | Kenmore Dishwashers
How to unlock control panel LFFH21F7HWG?
Press and hold the Control Lock key for three seconds
to activate or deactivate the function. The Control Lock
feature prevents the user from changing the temperature
and freeze settings. At the first press of any key, the
key press click tone will be heard and the display will
show "LO", but no other change will take place. Holding
the Control Lock key for three seconds will activate or
deactivate the Control Lock feature. After three seconds,
the accept tone sounds and the Control Lock LED (if so
equipped) is activated. In lockout mode, when any key
is pressed, the invalid key tone will be heard and "LO"
will be displayed for 1 second. When the lockout is
deactivated, the Control Lock LED is turned off and the
display shows "UL"
if this does not work unplug the freezer for 30seconds then plug it in. if all of the above fails replace the control.
Jul 04, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How to reset a rascal control panal
To reset the control panel turn the key off then back on. If you are receiving a flash code, once the the code has been corrected restarting the with the key will reset the control panel.
Scooter Doctor App
Jun 01, 2014 | Rascal Used Electric Power Wheelchairs -...
How do I unlock my bosch washer dryer logixx 7/4. the red lock key symbol is on
Model WVH28420GB :
Firstly, follow the instructions for "Emergency Release" on page 13 of the Operating Instructions for this machine.
If, when you switch on the machine and select a washing programme after doing this, the key symbol still appears, press and hold down the 'Timer' button (second from top on the left hand side of the message panel) for a few seconds until the key disappears. Now operate the machine as you normally do.
Dec 04, 2011 | Washing Machines
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Health & Beauty Logo
157 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
