the player was left outside one night, and it got a little wet, so it's possible the components are fried. I opened it up and everything looks fine inside. When you put a disc in, the motor starts spinning, and the laser even works, but after a second or two it stops and the screen says "no disc."
all you need to do is to clean up the laser head ,using cotton & IPA solution.be very careful the laser head is very sensitive device.hope it would help,
Toshiba model # SD-P1400 was working fine however when we tried to play recently the screen was...
(More)
Toshiba model # SD-P1400 was working fine however when we tried to play recently the screen was almost black
switch power on/off no good .. broken for sometime i did pushed or press very hard with the...
(More)
switch power on/off no good .. broken for sometime i did pushed or press very hard with the finger... where i will find this part? Thanks...
Model # SD-P91SKN will no longer spin the discs. When I try to play a disc, it reads "No Valid...
(More)
Model # SD-P91SKN will no longer spin the discs. When I try to play a disc, it reads "No Valid Disc." It does not even spin the disc. I have only had this 6 months.
