Icon medialab projector -upside down picture
I have bought a Icon medialab projector model number is IN-228 i have ceiling mounted it but the picture is now upside down, dose anyone know how to turn the picture the righ way up i have gone through all the menu options and there is nothing to indicate that this can be done.
  • 1 more comment
  • aryan_8_shiv Mar 28, 2009
    Upside Down Pic
  • fighter-fish Apr 09, 2009
    i have the same problem can anyone help me
  • Jpitoniak May 21, 2009
    The picture is upside down and there is nothing in the menu to fix it that I can find.  PLEASE HELP!
  • 3 Answers
I can not find the manual for this projector, but on most projectors in the menu you select the position of the projector. You will need to select front/ceiling. If there is not a installation tab on your menu, look under setup. Hope this helps.
Posted on Mar 13, 2009
Optima Optima hd81 projector mounted on ceiling now picture is upside down
There is an option in the setup menus to re-orientate the picture, to flip it either vertically, horizontally or both to correct for the various installation options. You should be able to correct it quite easily :o)
Mar 29, 2014 | Hitachi PJTX100 Multimedia Projector
Runco picture upside down
Yes possibly because you have done a complete system reset and not a lamp hour reset so you will need to go into image or screen settings and select front view ceiling mount configuration
Apr 14, 2013 | Office Equipment & Supplies
My image is upside down after I mounted my projector to the ceiling
There are projection mode settings which will allow you to adjust the orientation of the image. Adjusting this setting will rotate the image so that it is not displayed upside down when attaching the projector to the ceiling.
To activate this setting:
  1. Press the Menu button on the projector.
  2. Using the Arrow buttons, select the Image icon on the left side.
  3. On the Image screen under the Projection label, select the icon that represents ceiling mounted projection. Note: You may see both front and rear ceiling mounted projection modes. You may choose which ever best suits your needs.
  4. Press Menu on the projector controls to exit the settings menu.
Nov 19, 2011 | Office Equipment & Supplies
Upside down picture
turn the projector up the other way,
or
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
Feb 22, 2011 | Epson EMP-54 Multimedia Projector
My bulb was replaced. We reset the bulb hours and somehow flipped the screen upside down. The projector is mounted upside down. What do I do? In trying to fix it, the remote quit working. I may have...
I guess you used factory reset, then picture flips back to table/ front mode.
In setting menu choose for ceiling ( R upside down icon) and set this to ON.
Jan 08, 2011 | Eiki LC XNB4 LCD Projector
Projector is mounted on the ceiling and display is upside down. how do I fix this?
Go to the setup menu and change the orientation. You will have a number of choices. ex. Ceiling front, ceiling rear. Select the position that the projector is mounted and the picture will reorient and display correctly.
Aug 25, 2010 | NEC MultiSync LT280 LCD Projector
We have inherited a Sanyo Pro-X multiverse projector without an instruction manual. The projector was fixed to a ceiling but we would like to use it freestanding. When attempting to use the projector this...
You need to turn off the ceiling mode to get the picture to project correctly. This is in the Settings Menu. See page 37 of the manual which is currently available here: http://cncms.com.au/SANYO-IMs/Commercial-Industrial/plcsw30_im.pdf .
Press Menu. Then use the left/right arrows to move to the icon with the projector and screen shown. (Note: right now this row will be on the bottom of your screen and the icon will be to the left side of the row.) Press the down arrow and move to the Ceiling icon with the R. It should be the seventh icon from the upside down "Up" arrow; it's next to the Capture icon with a camera. (Normally, ceiling icon shows as an upside down R when your image is projected right-side up. There is also a rear-projector icon with a mirror image R when the image is right-side up.) Press Select and then use the arrow keys to choose the On/Off options. You may need to press Select again to save the setting.
I hope this helps.
Oct 11, 2017 | Sanyo PLC-SW30 Multimedia Projector
I mounted my In Focus Projector upside down because of the ceiling mount I bought for it. Now the picture is upside down. How do I fix this?
Go to the Setup menu and select Orientation. In here, you will want Ceiling Front or Ceiling Rear depending on how you are using the projector.
Some projectors won't let you into the menus unless there is a computer connected. I'm not sure if this is one, but keep it in mind if you have trouble.
Sep 28, 2009 | NEC VT465 Multimedia Projector
How do i mount my hopper projector sv 10 to the ceiling
Yes it should be mounted upside down as you would not want to see the bottom of the projector all the time, unless the bottom is as good looking as the top, which I doubt. I wonder if you bought or got a ceiling mount rack with it. First mount the rack on the ceiling and then fasten the projector to it. And before that its picture has to be turned upside down too.
Aug 11, 2009 | Philips Hopper SV20 Replacement Lamp -...
Settings on ViewSonic PJ513D Ceiling Mounting
The user's guide says for ceiling mounting,
"Set Front Ceiling in the System Setup: Basic > Projector Position menu after you turn the projector on."
The user's guide is on the CD included with the projector as a pdf file. You can also download the user's guide here:
http://www.viewsonic.com/assets/006/5619.pdf
If you find this solution gives you what you needed, please take a moment to rate it. Thanks for asking here!
Feb 22, 2009 | ViewSonic PJ513DB Projector
1,083 people viewed this question
jasbo
jasbo
