Question about John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor
How do you clear codes on a john deere 4210 - John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor
4 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: John Deere 4210 brakes are locked up
On both sides of trans housing just in front of axles is where brake shafts go into trans.To fix this you have to spray alot of lube between shaft and housing while trying to rotate shaft.This may take hours to free up and also check for the return springs to still be hooked up to lower roll bar frame.I have seen this alot in the 4000 series tractors.
Posted on Nov 14, 2009
  • 5 Answers
SOURCE: where is the drain plug
There should be a pipe type plug in the bottom of the transmission housing near the draw bar inline with the rear axle housings. Whether you have a hydrostatic drive or gear drive, the plug is in the same place. Reference # six in drawing.
Posted on Feb 17, 2011
  • 100 Answers
SOURCE: Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Posted on Oct 26, 2012
Wiring diagram for john deere 4210, particularly tail and brake lights
Try PartsTreeRepairClinic or PartsTree.com one of the 2q may help
Feb 03, 2018 | John Deere Garden
Where do I find all the Error Flash Codes for a John Deere 4410
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
JOHN DEERE 4210 4310 4410 COMPACT UTILITY TRACTOR OPERATORS MANUAL...
Nov 17, 2016 | John Deere Garden
Where are the transmission drain plugs on a john deere 2020 tractor
It is located on the bottom of the transmission reservoir, and that is 1 foot to the right from the battery.
Oct 21, 2013 | John Deere Seat 4210 4310 4410 4510 4610...
John Deere indicator code
Call your JD dealer they should help you it could be as simple as a light bulb out.
Oct 22, 2011 | John Deere Seat 4210 4310 4410 4510 4610...
John Deere 4410 PTO error code. One long flash, one short flash and then six short flashes.
Check the wires on the solenoids.
http://www.tractorbynet.com/forums/attachments/john-deere-owning-operating/39426d1117768879-4410-power-take-off-stopped-665916-solenoids.jpg
Items L, M, N are mid PTO, MFWD, and rear PTO respectively
Also look at the skid plates as the possible cause of wire damage. A cheap spot / zip tie will keep the wires away from any future damage. Often the wires are damaged / torn off by a foreign object striking the Solenoid.
Thanks for choosing FixYa,
Kelly
Jun 19, 2011 | John Deere Seat 4210 4310 4410 4510 4610...
Where is the drain plug for the transmission on the john deere 4210 tractor
Feb 16, 2011 | John Deere Seat 4210 4310 4410 4510 4610...
My 4210 4x4 with hydrostatic drive quit driving runs well but will not travel forward or reverse
Hi, the engine will power the hydrostatic drive via a drive belt. See that this belt is in place or if it is worn out and loose. By replacing this belt you should get your machine running again. Hope this helps
Nov 17, 2010 | John Deere Seat 4210 4310 4410 4510 4610...
John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor Logo
248 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
