Question about Contoure RV Convection Microwave - Black Trim Kit
Contoure CMC11040B Convection does not reach desired per heat temp
How to set temperature
Try going to the web site for a user manual download.
Mar 29, 2016 | Contoure 1.1 Cubic FT. Convection...
I purchased an RV with convection grill bit need a owners manual. I want to use it properly
Best to contact the manufacturer. You may use a Yahoo, Google, Bing, or other search engine to find the manufacturer's website, and contact their "Customer Support."
May 05, 2015 | Contoure Black Microwave Convection Grill...
Why does our GE jt910 oven not heat consistently when baking cookies. the first batch is ok but second batch is always over done?
Buy a small oven thermometer and check the temperature of the heating oven over time. It may not explain it, but you can better adjust the dialed temperature to match the desired temperature.
Jan 27, 2015 | GE Microwave Ovens
How do I get the heat to work?
Hi Marc, there is no 'heat' per say with microwave ovens as one would find in a convection oven. Microwave ovens operate by generating electromagnetic fields (within the microwave band) that causes water molecules in the food item to vibrate/rotate creating friction/heat - within the food item as opposed to the surrounding space (this would be convection)
Oct 26, 2014 | Oster Microwave Ovens
Panasonic microwave does not achieve desired temperature
They never do ! You have to check the temp at where the air comes out of the fan and you need to use a remote electronic thermometer.
the old oven type won't work sitting on a the shelf. 275 degrees at best. Take it back it's not broken ...the just don't work as advertized
Apr 07, 2014 | Panasonic NNCS596S Microwave Oven
Gas oven heat does not reach the desired temp
Go to your local appliance parts supplier and they will have an exploded view of all the parts and you can just pick out the thermostat.
murf427
Aug 30, 2012 | Microwave Ovens
My Sharp microwave convection oven (R-967M / R96STM) cuts out during convection pre-heating and cooking, It appears it stops heating after 1 min. If the START button is pressed again the oven starts...
Also the fact it is a convection oven could mean the oven temperature sensor is not picking up the oven temp. it is not telling the machine it is there by the board seeing its resistance, the unit will shut off as a safety feature. The oven sees temperature by reading the value of a temperature dependent resistor. As the temperature changes so does the value of the component ( oven temp sensor) that way the unit determines the temperature inside the unit. Sometimes those sensors will break since they are in the area with the heat and moisture, they get old and break.
Aug 17, 2017 | Sharp Microwave Ovens
Only heats to 325 degrees in convection mode. takes long time to reach this temp.
Hi two possabilities here, either the element or the thermostat is faulty and will need to be replaced.
Jan 07, 2010 | Amana AMV6177 Convection/Microwave Oven
Sharp R-1874F Low Convection Temp
We have the 2 service manuals you need to refer to for this model and have uploaded them to our site here and here to help you.
You will need the
free Acrobat Reader to view or print them in case you don't have it.
The manuals have a safety info, disassembly info, troubleshooting chart, test procedures, part numbers, etc.
I would first suspect a bad thermistor, but it should be checked, as well as the line voltage at the outlet, etc.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Jan 08, 2009 | Sharp R-1874 Convection/Microwave Oven
GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(At that site, that part is misspelled as "thermister" for your model).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jan 02, 2009 | Microwave Ovens
Contoure RV Convection Microwave - Black Trim Kit Logo
27 people viewed this question
Top Contoure Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Contoure Microwave Oven Expert? Answer questions, earn points and help others
