I have a whirlpool denver 1600. When it spins it gets very noisy and i hear a banging noise when it starts to spin. can you help me find the problem and how to fix it
Coldcut
  • 1554 Answers
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
  • 68 Answers
SOURCE: loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Posted on Apr 26, 2009
SOURCE: excessive noise
I had the same problem. Two things were bad. One was the shock absorber and must be changed out as a pair. Also one of the springs that supports the tub was broken. My guess is that the spring broke and the shock failed shortly after. since it was more easily accessible and appeared to be the problem, I replaced the broken shock. Only to find the spring was broken too. After replacing the spring, its worked fine for a couple of years. Obviously I'm looking at this site because I'm having another problem, but this time I think it is the tub bearing.
Posted on May 13, 2009
  • 353 Answers
SOURCE: Whirlpool Duet GHW9150P Front Load Washer is
BEARINGS
Posted on Dec 15, 2009
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
Noisy
Thanks for choosing FIxYa and welcome to the site. If you are hearing noises during spinning, you could have a bad motor drive or a bad spin bearing. Check at the motor and pumps for noises as well. Check to make sure no belts are causing the noise. Let me know what is making the noise. Where is it coming from? What cycle please?
Apr 26, 2011 | Whirlpool AWM6100 Front Load Washer
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer has recently started thumping and banging during the spin cycle. I thought it was uneven weight distribution, but it does it every spin now. And when the spinning slows down it has started...
Hi, . according to your washer problem i m writing solution ,please read and follow it:-
  1. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
  2. check out this following options one by one to locate the fault in your machine.
  3. 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.4)Clear thewater pumpfrom obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  4. you can get the required partys from
  5. www.repairclinic.com
  6. I hope this will help.
please don't forget to vote me. goodluck.......
Jan 21, 2011 | AEG Lavamat 72640 Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
Noisy Spin Cycle
hi there,
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
