Question about Fisher and Paykel Fisher & Paykel Washer
My smart drive is not reaching full spin speed on spin cycle
I just unblocked the pump on my smart drive f&p machine and thought it was all fixed only to find that when it reached the spin cycle it starts off ok sometimes but will not reach full spin speed and ends up not getting the water out the clothes properly as spin is too slow. can you help? It cannot complete the spin cycle properly. It was laid on its back when the pump was fixed and I have just been told this is a no no.
You are right with your last comment. Laying the machine on its back is a no no. It allows the residue water in the bowl to possibly travel up the small plastic tube and enter into the water level sensor on the main (computer) control unit. It only takes a very small amount of water and it upsets the sensor so that the machine may not go through its cycle correctly. The water (depending on model) is extremely difficult or impossible to get out.
This may cause the machine to think that the bowl is not completely drained and so it will not go into full speed spin. Other problems may occur as well.
Bear in mind also that that a number of machine models do not go to full speed spin on a water temperature setting of warm or higher. When checking for high speed spin put your water temperature control down to cold / warm or cold.
Check also that your machine is sitting level ( the bowl is sitting centre in relation to the top shroud. If the bowl is leaning toward the rear of the machine when you look down into it, the ability to spin may be affected. There is a lever behind the bowl which activates a switch if the bowl comes in contact with it (when the wash load is out of balance) to stop the spin. The switch can also be activated when the machine is not level.
If your problem persists you may have to get a replacement main contol unit. If you are a little savey at technical things you may be able to get a discarded control unit from your local tip or recycler and recover the water level sensor for a change over. This may involve soldering though as well as precautions concerning stored electricity in the control unit capacitors and precautions about static electricity from your body or solder iron destroying other electronic components on the main control unit.
Hope this helps.
Posted on Mar 28, 2009
My maytag neptune mah3000aww spins slowly then reverses, then spins slowly. will not reach regular spinning speed. What is the problem?
it could be a balance problem. Most machines are programmed to abort fast spin if the drum is unbalanced. This can be caused by too much in there, or possible the contents have clumped together somehow. Try a spin cycle only with an empty machine and see if it reaches full spin
Feb 18, 2015 | Maytag Neptune Washer Door Mah3000aww
Zwp1121p Spinning but clothes still we5 through
Is the spin cycle reaching full spin speed or is it not spinning as fast as it should? If it isn't reaching full speed it could be caused by an uneven load (as this will stop some machines from spinning properly). Towels and items which get very heavy when wet can cause this.
Oct 27, 2013 | Zanussi Washing Machines
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Smart drive 085
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
Sep 25, 2013 | Fisher and Paykel (IWL12)
My kenmore elite smart wash quietpak 9 won't spin
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. You can usually look and visually see the spot where the switch should be and if damaged. How to repair :
1) Unplug the machine. 2) At the head, or control panel, find the two screws that hold it to the case. Some are on the left and right front lower corners of the panel, and some are vertical facing s on the rear left and right side. Also on some models they are in the front but you have to pull the end caps off the sides of the control panel. 3) Remove the 2 screws and then pull the panel from the lower part of it towards you and roll it backwards. 4) Disconnect the lid switch connection in the the middle where the two grey wires and the green wire block connects to the body of the machine, usually near the middle under the panel. 5) with a flathead screwdriver pop out the two brass retainer clips on the right and left side. 6) Open the lid slightly where you can grab the case, not the tub, just the case, and pull forward and surprise!!! You just took the complete top, sides and front of the machine off. The lid switch will be attached to this portion so located it, remove the two screws that hold it in place, under the lid, and swap out with a new one. This is a cheap repair, just take your time and you'll be fine.
May 10, 2012 | Kenmore Washing Machines
Won't pump out water at the end of wash or rinse cycle.
I don't know this model at all, but hada similar set of syptoms on an electrolux .....
Just a thought, but have you checked the pump chanber is not impeded by a stray hairgrip, or bit of wire?
The fact it doesn't pump when it should, but allows water to pass when the centrifugal force of a spin cycle builds up, would indicate that maybe its the pump that either has a jammed impeller, or a blown motor (or fuse).
Feb 15, 2009 | Kenmore 23822 Top Load Washer
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Maytag PAV2000
Its possible that the machine is not reaching full speed during spin. Check to see if the belt is slipping and that the thrust bearing pulley turns freely. When in the spin cycle the thrust bearing compresses the brake directly above it. If this brake is hanging up even a little the machine cannot reach full speed. The diagram on the right shows the thrust bearing assy. and brake.754307c.gif
Jan 14, 2008 | Maytag Performa PAV2200
Washing Machines Logo
395 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
