Question about Siemens Seimens Arc Fault Breaker
Installing arc fault interrupter with ground fault
Can a ground fault interrupter be used in a bathroom with a ground fault interrupter? How many circuits can be installed in a 15 amp arc fault interrupter?
    Problem Solver:
  • 19 Answers
If you meant arch fault with ground fault then no, the two types interfere with each other and trip the breaker as one senses an arch and the other grounding.
If you meant ground fault breaker with a GFCI. receptacle, you only need one of the two, either GFCI. breaker or receptacle.
and for circuits, you can put up to 12 devices (i.e receptacle, light)assuming they consume 1 amp each. Anything over 12 amps or 80% of the rating on the breaker, it will trip/reset.
Or if your talking about wires on a breaker then no more than 2 wires recommended. Try adding a junction box outside the panel if your trying to add other branch circuits or tap off of a receptacle.
Posted on Jun 23, 2014
2 Suggested Answers
  • 5245 Answers
SOURCE: installing arc fault interrupter with ground fault
Question is vague. Arc fault and ground fault are slightly different.
Are you installing arc fault breaker?
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Code says Maximum 12 boxes per circuit breaker.
Arc fault breaker and GFCI outlet in bathroom?
>>> do not connect this way.
Do not install 2 fault protections on same circuit.
Install the arc fault circuit breaker, and then remove bathroom GFCI, and replace with ordinary outlet, or switch-outlet.
How many outlets can be connected to a bathroom GFCI?
It depends on total boxes on circuit.
Count the boxes. Max 12 boxes per circuit breaker.
How many amps can be connected to 15 amp device?
15 x 80% = 12 amps
Electricians use 80% rule to calculate safe maximum
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment
Posted on Apr 22, 2013
Karcher electric pressure washer help starting
The test / reset buttons are for a Ground Fault Interrupter built into the cord / washer. This device will help prevent deadly electric shock in the event of a malfunction - it is the same technology used in "GFI" electrical outlets located in bathrooms, outdoors, basements, etc.
You should have this serviced - or replaced before using.
Sep 18, 2015 | Karcher Garden
Our plug in beside the sink in our 2012 fun finder not reset. also effects the bathroom plug.
The plug-in should be a GFCI unit (Ground fault circuit interrupt). If the unit will not reset there is either a short in your wiring, possibly a wire came lose, or the GFCI unit is defective. Unless you are familiar with electrical wiring, this is a repair that should be done by an electrician.
Oct 22, 2014 | Cruiser RV 2012 Fun Finder X X-189FBS
Installing sprinkler timer
GFCI is just a protected plug for use in wet areas - like Te one in your bathroom. Your sprinklers will work fine plugged into a regular outlet but it may void your warranty if something happens. If your timer is outside or not well protected from weather then consider installing one of these outlets. 7_11_2013_1_40_33_pm.png
Jun 22, 2013 | Garden
15 x 80% = 12 amps
Add a comment
Apr 21, 2013 | Siemens Seimens Arc Fault Breaker
Ground fault from box
In California It is code to have a ground fault receptacle where ever water is, Bathrooms, kitchen, laundry ect.
I have a older home that has 1ground fault for all receptacles located in the garage, so to update I have installed ground fault receptacles in all locations where water or dampness is present, even under the kitchen sink cabinets.
Apr 22, 2012 | Cars & Trucks
How to replace a Bryant GFCB120 Circuit Breaker
If you have a Bryant load center, you can use other breakers in it, including the Eaton GFCB120 GFI since several companies unified their design. The GFI (ground fault interrupter) or GFCI (ground fault circuit interrupter), same thing, may be required for a device you are installing, such as bathroom, kitchen or outdoor fixtures.
The Eaton series includes very clear installation instructions, but if your problem is that they are missing, then all you do is install the breaker in a open slot in the breaker panel, but you have to attach the neutral [white] wire differently. On regular breakers, the neutral goes right to the ground lug in the panel. With a GFI breaker, it goes through the breaker, and then is connected to the ground lug.
Mar 09, 2012 | Eaton Corporation GFCB120 GFI Circuit...
Breaker box has power but my bathroom light and kitchen ceiling fan wont go on
See if there are any ground fault circuit interrupter outlets in either room. Look especially in the bath. There are black and red pushbuttons on them. Press the reset and see if that helps.
Gary
Aug 29, 2011 | Home
I am installing a Jacuzzi tub in my basement , no heater , What size circuit breaker , and what number wire should i use .
This is a code based issue, and you MUST, MUST have a GFCI (Ground fault circuit interrupter) The tub should have the capacity specified on its box, somewhere. This job requires a permit in most areas, and serious liability exposure is present, and your insurance may not cover, without permits and inspections....
Feb 28, 2011 | Whirlpool 5"x36" White Bathroom Drop-in ...
We have one of those breakered receptacles in our bathroom and the buttom seems to be stuck and won't allow it to reset fully. Does this mean it needs replaced or is there a way to 'un-stick' it?
I presume that you are talking about a Ground Fault Circuit Interrupter. GFCI plug...
Eventually they just fail. Replace it, it is your safety that is on the line. Be sure that power is actually going to the plug. If there is another interrupter up stream that tripped, you can have the condition that you describe.
Turn off power before handling the plug. Also, look closely at which terminals you hook up to on the back of the plug. One set of connections is to allow for downstream socket protection, and not for power in. Some installations have one GFCI plug in one bathroom, and all other bathrooms are wired onto the downstream output terminals of the first plug. Kind of confusing for home owners, I think, when the circuit trips, now you have to go to OTHER bathrooms and check the outlet there... My preference is GFCI at the location where the user plugs in.
Nov 19, 2010 | Hammering
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
Siemens Seimens Arc Fault Breaker Logo
194 people viewed this question
Top Siemens Electrical Supplies Experts
john h
Mike
Gene Haynes
Are you a Siemens Electrical Supply Expert? Answer questions, earn points and help others
