Question about Vizio L32 32 in. LCD HDTV
Vizio L32 HDTV10A "Display / Sound / Mute / Volume Problems"
I have 4 peaces of Vizio L32 HDTV10A and all is giving the following problems.... 1 - NO Display but hearing Sound 2 - NO Sound but seeing Display 3 - When mute the sound, the audio is not muted 4 - When Volume is ON, there is NO Sound 5 - The Sound is at Full hears volume, but the volume control is on 0 volume level or to it's lowest volume level and still hearing sound loud 6 - At random times the TV wil turn OFF or the LED Power light change to Amber Color 7 - some times the TV will not Display and No Sound, but the Power LED will stay at Green What I tried: 1 - I open the TV and troubleshoot until the HIGHT VOLTAGE INVERTER for the Screen Lights, the brown wire, when the screen don't light up, the brown wire reads at 3.2Volts, it seem as the protection is ON! if you put down the 3.2Volts to ground, the Light will flash on for a second, more or less the brown wire voltage may have to be at a set voltage to be ON! also for the sound I still haven't reach that area as yet! This TV look as it have a formware or some malfunction to it's main IC due to the above problems with all 4 TV's... please do email me with any help....thanks RandyXi wizztech@gmail.com
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
SOURCE: only vizio light on
RJW34 I have a 37" Viizio LCD that has a similar problem. I power it up and I get a lit screen but it's blank. No controls work except power on and off.
Posted on Feb 20, 2009
Axle80
  • 73 Answers
SOURCE: vizio p42 type sp42a nov 2004 hd tv
The sp42a is a plasma tv not an lcd. check the psb voltages first then move onto the ymain and buffers.
Posted on Aug 25, 2009
  • 13 Answers
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Posted on Jan 22, 2010
SOURCE: TV looses picture and sound. Will not turn back on
www.plasma-television-repair.com/Sample-Preview-Plasma-Tv-Repair-Training-Manual.pdf -
Above is a training manual, this should help you find and fix the problem if you wish to DIY. If you DO, decide to DIY, you MUST MUST get a Service Manual, for your exact make & model. it will be similar to the Training manual, but explicitly for your set. I do not recommend it however.In my professional opinion, you should contact Vizio and ask for an approved local service center, then, get a "Quote" for repair.
With faults such as this, it is important to leave them disconnected from the wall, as it is entirely possible, for a faulty, TV, to cause a fire, an explosion, or both. Anytime one hears any sort of "pop" similar or not, is grave cause for concern, as usually this means some sort of component failure, in a high voltage area.
Posted on Apr 29, 2010
My VIZIO vx32L/hdtv10a remote only lets me change channels. No volume up/down or power on/off function either
If your audio is being routed through a home theater system then you will not get vol control through the remote for the TV. You will have to use the home theater remote.
Feb 22, 2015 | Vizio L32 32 in. LCD HDTV
Vizio e420 sound problems
1. Press volume up on the remote control. 2. Press the MUTE button on the remote to ensure mute is off.
3. Check the audio connections of external devices (Blu-ray player, game console, cable/satellite box) that are connected to the TV.
4.If you are using an antenna, the signal strength of the channel may be low. Ensure your antenna is connected securely to the TV and move the antenna around the room or close to a window for the best signal.
If you tried the above and still have sound problems, use your menu and check the audio settings to make sure they a right. You may have to reset the audio.
Feb 22, 2013 | Vizio E420i-A1
No picture no sound on a Vizio HDTV10A. The green light comes on then turns to amber after a couple of seconds
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Feb 01, 2013 | Vizio 32" l32 hdtv 10a high definition...
Sound went out
http://www.retrevo.com/support/Vizio-L32-TVs-manual/id/512dj084/t/2/ Above is your user manual, below is your service manual. Check, your Mute, isn't on? nationalservicealliance.com/visio/VIZIO-L37HDTV.pdf
May 27, 2010 | Vizio L32 32 in. LCD HDTV
Only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Only vizio light come on then nothing. have to unplug to turn off
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
1,258 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
