Question about Weed Eater Weedeater 26" Riding Mower
My Weedeater riding lawn mower will not move in forward or reverse after it has started
While cutting my grass the mower stopped and when I restarted it, it would not move forward or in reverse.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 118 Answers
Check your drive belt that it has not slipped off.. also check your drive lever on the right side (speeds, neutral, and reverse). The mower uses this lever to angle the motor against the belt to move it..
It is most likely the belt or the angle misaligned if the engine is turning...
Posted on Jun 20, 2015
Toro Timecutter MX5050 74770 won't move forward or reverse.
find a breakdown of the parts diagram. that may help.
Sep 25, 2016 | Toro Garden
My Weedeater riding lawn mower will not move when it is in drive or reverse
Check your drive belt that it has not slipped off the drive cog under the motor. Also check the alignment of the motor with the handle on the right side (speed, reverse, and neutral lever).. This lever tilts the engine to engage the drive belt.. there is no transmission in this machine.. just how the belt engages by its angle when you push the lever forward and backward.. If the engine is running, it must be either the belt to drive the unit or the angle has been messed up somehow..
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
I WAS RIDING MY MOWER, WHEN I DECIDED TO CUT SOME GRASS, I STOPPED THE MOWER, PUSHED IN THE CLUTCH, ENGAGED THE BLADES, THE BLADES STARTED MOVING, I THEN PUT THE MOWER IN FOWARD LET OFF THE CLUTCH AND...
2 things, one, the belt jumped track, broke, or melted in place, 2, the hydrostatic ****** is out of oil, you didn't say if it was hydro or not. I doubt that the gear box has gone bad, but I would put more blame on a belt or pulley. Check it out. Hope this helps.
Mar 17, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My Husqvarna YTH21K46 start's up good, But will no go forward or reverse. Iwas cutting grass for about 15 minutes, then the clutch pedal began shaking, but still going forward and reverse. i decided to...
There should be a pulley that the brake/clutch petal pulls against to disengage. You could have a problem with that. You will have to turn it by hand to check and see. Check the main drive belt while you are in the area. It may be helpful to remove the deck so you can slide up under there get a good look.
I hope this gets you going.
Aug 11, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Hi. I have an Alko T18-102HD ride on lawn mower that is starting to go very slow in reverse and forward. It gets to the point of slowing to a stop when reversing up a slope. I fitted a new drive belt...
I had the same problem with my Alko going slow in forward and reverse. Believe it or not the problem is caused by a build up of grass cuttings around the hydro clutch mechanism. If you follow the mechanism from the foot pedal you will probably find the actuator is being prevented from engaging by a build up of old grass. Clean it out and you should find it restores normal operation. This has happened to me a few times so now I blow out the grass on a regular basis with an air compressor which stops me having any problems. It also stops a hefty bill from the service dealer :-)
Jan 14, 2011 | Garden
Cub cadet starts but won't move forward or reverse ? what should i try to do?
What model? I have a 1554, that I just took to the dealer, for repairs, for the same thing. The motor starts, the blades engage and cut, it just stopped moving forward, or reverse. If I remember, I'll get back on here and let you know, unless you already know?
Apr 12, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Lawntractor does not move forward or backward
you might check the pulleys to see if shear pin has broken.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Weed Eater Weedeater 26" Riding Mower Logo
327 people viewed this question
Top Weed Eater Garden Experts
David Payne
David Payne
Lawrence Oravetz
Bonard Allen
Are you a Weed Eater Garden Expert? Answer questions, earn points and help others
