Question about Frigidaire PLDB998A Built-in Dishwasher
My PLDB998AC1 dishwasher reports PF everytime I run it
For the last couple weeks every time I run the dishwasher I get a PF (Power Failure) indication on the front panel. HI-TEMP WASH and POWER DRY OFF/NO HEAT DRY indicator lights will also flash. The dishes are washed but not dry. I haven't watched to see that it happens everytime on the dry cycle.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: frigidaire dishwasher FDB1500LFCO is not
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 20, 2011
I need to know what the error code pf means for a frigidaire gallery model #fgh202465nf1a
Hey Carol, I understand that you are receiving an "PF" error message on your Frigidaire Dishwasher. Typically this error code indicates a power failure. Before considering contacting a service provider, I would recommend resetting the dishwasher by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the appliance to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
Oct 11, 2015 | Frigidaire Dishwashers
Frigidaire dishwasher pf dims and stops
Hello Colton Rawlings, thank you for your post!
Based off what you are describing "PF" stands for power failure on a Frigidaire dishwasher. If the lights are dimming then your appliance flashes "PF" it could possibly be an issue within your panel or your appliance is not getting enough power to it. I would recommend contacting a professional to come and diagnose your appliance properly. I hope this is helpful. -Matt
Sep 06, 2014 | Frigidaire Dishwashers
PF code comes on
Check all the wiring to the dryer and even the wires in the wall socket. Sounds like there is a loose wire since you keep getting the power failure (PF) code on the dryer.
Dec 27, 2011 | Whirlpool GGW9868K Gas Dryer
My frigidaire dishwasher works intermittently. It'll completely stop mid -cycle, as if the power was shut off - then eventually indicate a power failure on the display. Then it wil work fine for a c
Hello Tom Weiss, There are a couple of things to check.
1. Check connection at the dishwasher. It is possible that the wire nuts came lose. Re-tighten and wrap with electrical tape to secure.
2. Check for a small leak from sink or faucet this has also been the culpret before.
Dec 05, 2011 | Frigidaire Dishwashers
The PF(power failure code) comes on several times
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Jun 03, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Display shows PF
This is an indication that the power to the unit has been interrupted (Power Failure)
May 27, 2009 | Frigidaire Dishwashers
The dryer will not turn on its flashing pf
PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display.
Apr 15, 2009 | Whirlpool ET8CHEXSQ Dryer
PF indication
You are having a power issue with the plug outlet or the junction box at the bottom right of the dishwasher.  To be sure, run an extension cord and use a different outlet in the kitchen.  If after a couple of loads, the PF problem doesn't come back, have the outlet checked.  If it does, you will need a qualified LG tech to come out and see what's going on.
Mar 27, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
Frigidaire PLDB998A Built-in Dishwasher Logo
51 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
