Question about Allied Telesyn Computers & Internet
PAssword Recovery for Allied Telesis 8000s
I have set a password, and cannot now remember it - How can I recover this?
  • tittu Jul 26, 2013
    Bits per second: 115200 Data bits: 8 Parity: None Stop bits: 1 Flow control: None During booting you will see: Boot1 Checksum Test...............................PASS Boot2 Checksum Test...............................PASS Flash Image Validation Test.......................PASS BOOT Software Version 1.0.0.05 Built May 9 2006 11:56:50 ATI8000 board, 88F5181 CPU based with ARM926EJ-S core. 64MByte SDRAM. I-Cache 32 KB. D-Cache 32KB. Cache Enabled. Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom. Please press RETURN or Esc to enter in the prom menu and press the key [3]. Startup Menu [1] Download Software [2] Erase Flash File [3] Password Recovery Procedure [4] Enter Diagnostic Mode [5] Set Terminal Baud-Rate [6] Stack menu [7] Back Enter your choice or press 'ESC' to exit: 3 Current password will be ignored! ==== Press Enter To Continue ==== Exit from boot menu. Continue with flow. Please issue the following sequence: console> enable console# delete startup-config Delete startup-config [y/n]? y Startup file was deleted console# 01-Jan-2000 01:01:39 %FILE-I-DELETE: File Delete - file URL flash://startup-config console# reload
  • 104 Answers
Try
usename: manager
password: manager
also try
usename: manager
password: friend
Posted on Mar 23, 2009
    New Friend:
To reset the switch configuration, follow theses steps:
1. Connect to the switch via console
2. Reboot the switch
3. As the switch is booting, press enter to access the boot menu
4. Choose: 2. Erase Flash File
5. You'll be asked to enter the flash file name, the file will be 'config'
6. Exit from the boot menu and let the switch boot as normal
You should now be able to login with the default username and password( UN: manager PWD: friend)
To connect a terminal to the device Console port, perform the following: 1. Connect a cable to the terminal running VT100 terminal emulation software. 2. Ensure that the terminal emulation software is set as follows: a) Select the appropriate port to connect to the device. b) Set the data rate to 115,200 baud. c) Set the data format to 8 data bits, 1 stop bit, and no parity. d) Set flow control to none. e) Under Properties, select VT100 for Emulation mode. f) Select Terminal keys for Function, Arrow, and Ctrl keys. Ensure that the setting is for Terminal keys (not Windows keys)
Posted on Feb 23, 2016
how to break password of a allied telesis 8000 series switch with version 1.3.3.1
Posted on Jul 26, 2013
Tip
ZIP Password Recovery Tool
ZIP Password Unlocker is to recover ZIP password and recover WinZIP password for you to get into the archive. No matter how long or how complex your password is. This ZIP password recoverytool supports all versions of ZIP/WinZIP files with powerful functions.In addition to brute-force attack, it also offers a brute-force withmask attack for if you still remember part of the password. It is fullycustomizable too for you are allowed to create a dictionary file forthe program to base on. The program is super easy to use even a newuser can get used to the program in less than a minute to recover ZIP password and recover WinZIP password.
Features Of ZIP Password Recovery:
Supports all versions of ZIP/WinZIP files
Recovers long passwords in WinZIP/ZIP files
Easy to use for a new user is guaranteed to fully use it in less than a minute
Fast in speed to recover ZIP password and recover WinZIP password
Allows to offer password clues to the program to reduce the calculation, saving time
Allows you to create a dictionary for the program to base on
Allows you to set the mutation numbers
Allows to set computer CPU priority for a better performance
Automatically saves the recovery process every after a period of time
Supports to resume if accidentally stopped last time
Automatically shuts down computer after recovery
Supported Versions:
All WinZIP/ZIP files are supported.
Other relative articles:Thirteen steps to recover forgotten windows xp administrator password with Windows XP CD
on Apr 19, 2010 | Computers & Internet
Tip
Word Password Recovery! Word Password Reset! Word Password Retrieve!
In most companies’ offices, *.doc (Microsoft Word) documents are probably the most widely-spread files used by employee. To protect the information, users often set a password for *.doc files. This is a convenient way to restrict access to the file when users exchanged and store information. The problem appears when you forget or when an employee who set the password leaves the job and the password isn’t recorded anywhere. If this happens, how do you get out of the situation?
Well, as far as I know, there is a lot of software can recovery word password, and they focuses on recovering Word password with three attack modes, Brute-force Attack, Brute-force with Mask Attack and Dictionary Attack.
Brute-force Attack for passwords with nothing know on the password, it means the program will do a full-scale search and try all possibilities randomly in order to get the password guess with the correct password and recover it.
Brute-force Attack with Mask Attack is commonly used when some password features are still remembered. For instances, the possible password length, any digits, letters, special characters like pond, dollar, or asterisk in the password. What are the first or last characters of the password, etc.
This allows users to define a password mask to minimize the guess test load and maximize the recovery speed. You can choose this attack if you still remember part of your password. For example, if you still remember your password is four characters and begins with "z", then you can define the mask as “z???” Thus reduces the detecting scale for the program, as it will only seek for the last 3 characters instead of 4 characters of the whole. To use this attack, a password mask must be defined.
Dictionary attack allowed you to create your own dictionary for the program to base on Brute-force with mask attack helps to reduce the password search time.
In order to offer you the best software, I have tried all password recovery tools I can found, and according to my experience, I recommend you Word Password Recovery 5.0 your best choice to retrieve your password.
Features:
1. All versions of MS Word are supported
2. Recovers all types of passwords
3. Recovers Word 97-2007 open passwords using advanced password recovery
4. Instantly recovers or resets all other types of passwords: open, modify, write reservation, form and document protection passwords
5. Support for simultaneous processing of several password recovery projects. Several attacks (using different attack profiles) can be conducted on one file simultaneously.
6. Program automatically saves password search state and can resume after a stop or a crash
7. Includes a Wizard for easy setup of password recovery attacks
8. Free updates during 1 year
The Password Recovery Official site: http://www.recoverlostpassword.com/
on Mar 16, 2010 | Computers & Internet
Ho to reset a the password of a allied telesis x900-48fe switch
The default password is the only one available
At the login prompt, enter the login name and password as follows:
Login: manager
Password: friend
Oct 06, 2014 | Computers & Internet
AT-8000GS/24 reset password with out reset button
Forgot or lost the password
Contact Allied Telesis Technical Support for assistance.
Apr 22, 2014 | Allied Telesyn ?AT-8000GS/24PoE 24-Port...
How do i reset my at-8000s switch to factory default by using command
follow this step
KIMIA# delete
startup-config Delete startup configuration (Reboot from defaults)
flash:// Delete a file from the flash (flash://filename)
WORD Specify name of file
KIMIA# delete startup-config
<cr>
KIMIA#
User Name:manager
Password:friend
console#
console#
Mar 29, 2012 | Allied Telesyn Allied Telesis...
How can a person unblock microsoft word 2007
Asunsoft Word Password Recovery is one of the most popular Word Password Recovery tool in the market, which can help you crack a password of Word in whichever versions, 97, 2003, 2007 or 2010. It has a high speed that has optimization for multiprocessor systems so a password with 6 characters can be recovered with several minutes. A password made up of less than 3 characters can be recovered within 1 second. Supports using multi-core to accelerate the password recovery speed. It offers three powerful attack types: Brute-Force Attack, Brute-force with Mask Attack and Dictionary Attack, so that it can greatly shorten the recovery time if you partially remember your password.
Asunsoft
Office Password Recovery is an all-in one MS document password recovery tool which can crack password of Microsoft Word, Microsoft Excel, Microsoft PowerPoint, Microsoft Access, and Microsoft Outlook. It offers a professional set of features wrapped in a very user-friendly form that is easy to master. It offers three powerful attack types: Brute-Force Attack, Brute-force with Mask Attack and Dictionary Attack. Supports using multi-core to accelerate the password recovery speed. What's more, it is easy to recover a password if you still remember the password partially that you can setup the program to crack passwords which including part of the password.
Asunsoft
Word Password Remover is a must-have password recovery tool which has the highest speed for you to crack Word password and has 100% recovery rate. As some customers said, Word Password Remover is powerful that it can instantly recover my Word password. Don't worry about anything when you forgot Word "open" password. Use this tool to recover the lost password you just need several seconds, and you can recover Word password with online service. The usage is very simple that you just need to click OPEN button to import a locked Word document and click Remove. Seconds later you can open it without password.
Nov 18, 2009 | Microsoft Office Professional 2007 Full...
How to Allied Telesyn Switch password reset?
The Allied Telesis website says this:
How do I recover a lost user's password on Layer 3 Switch or Router? ...
If a user forgets their password, the password can be reset from an account with MANAGER privilege, using the command:
SET USER=login-name PASSWORD=password
Another website has this to say:
device has a reset button.. you can push that via pen, check the devices handbook you will see that mini button..
push that button for a ten second... and release.. your settings will reset.. default username : manager password: friend
Jul 18, 2009 | Allied Telesyn AT-8624T/2M (AT8624T2M10)...
Password recowery
you forgot to tell us what password you want to recover.such as windows or office,if you are searching some password recovery software,you can enter the website http://www.recoverlostpassword.com/products/products.html,
that you can find some password recovery software ,such as Windows Password Recovery 6.0,Office Password Recovery 5.0 and so on.
If i am helpful please rate me.
Mar 27, 2009 | Allied Telesyn AT-8648 48-Port Ethernet...
Computers & Internet Logo
7,213 people viewed this question
Top Allied Telesyn Computers & Internet Experts
Prashant M
Prashant M
Are you an Allied Telesyn Computer and Internet Expert? Answer questions, earn points and help others
