I have a JAMO SW410E subwoofer and would like to connect it to my Denon AVR-2309CI AV Surround Receiver, I'm not sure if it's possible but I would like to know if i can and how to do so. Thank you.
5 Suggested Answers
sanjin
  • 56 Answers
SOURCE: I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Posted on Mar 18, 2008
  • 121 Answers
SOURCE: dayton sub-100 connection
You have it upon one of several truly odd "standards" in the AV industry but the answer is simple if not quite logical. You will use an RCA type cable from the Sub out or LFE on the receiver to just one of the two inputs on the subwoofer. I usually use the one on the right but it really doesn't matter. The other connectors would be for a system with out a sub out where the speaker wire would be run first to the subwoofer and then out to the speakers. This will not be used at all in your case.
Enjy!
Posted on Feb 27, 2009
dunnbiker
  • 8546 Answers
SOURCE: i cannot connect my bose
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
The reason: You can't use the Active EQ (or ANY processor) in a tape Monitor loop with anything but 2-channel stereo material. As soon as you activate the loop you lose digital sources.
Adding to YOUR particular problem is that the Denon doesn't have a volume-controlled pre-out to feed that amp. If you want to deal with controlling the separate amp volume manually you COULD connect the Active EQ between DVR Out and the 901 amp IN but you would have a stereo mixdown instead of true front channel from the speakers.
Bummer.
Posted on Apr 28, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a Denon AVR 3805 receiver. It does not have
By properly, you must mean WITH the Active EQ.
According to this picture, you're in luck BUT...
http://www.audioholics.com/reviews/receivers/denon-avr-3805/denon_AVR3805_rear_lg.jpg
(Short answer from personal experience.)
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers. A good 100-wpc amp will do. (I like Carver)
Connect the Active EQ between the Front pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Helpful Hint: If you don't have sufficient between-speaker room for proper reflection off the front wall you CAN turn the 901's around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Why won't my a102 speakers from jamo witch came
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Sep 01, 2014 | Audio Players & Recorders
My a102jamo surround sound speakers and working
Aug 31, 2014 | Audio Players & Recorders
I brourt a jamo sub 200 and five a102speakers but
I have a JAMO SW410E subwoofer and would like to connect it to my Panasonic SA-PM19 stereo system, Im not sure if its possible but I would like to know if i can and how to do so. Thank you.
Sorry to said but Jamo SW410E is an active subwoofer. This means that is has his own amplifier for the speaker (that why you can see at the back panel of the sub the RCA connectors for Left and Right (line in level):
In the meantime your Panasonic SA-PM19 stereo system has none connector for audio out (except the one for the heaphones). So it's not possible to connect these 2 audio devices together.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 03, 2011 | Panasonic Audio Players & Recorders
I am trying to hook my Bose Acoustimass 15 Series II surround speakers using a Denon AV Surround Receiver AVR-1804/884 to my Sony DVD player and Panasonic LCD TV. I have the speakers all connected...
If the speakers work with test tones this has nothing to do with them and all to do with your attachment and setup of the sources.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-1804-Receivers-manual/id/363bh837/t/2/
Stop guessing. Have you looked at all the manuals?
The other devices you're inquiring about are not named in your post. Name the makes and models first, then we'll look for the manuals. Then (maybe) find a solution. You could run them by the manufacturers' support sites or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
Google search: "(product) manual"
Apr 18, 2011 | Denon AVR-1804 Receiver
I cannot connect my bose 901 series v1 active equalizer to my denon av surround receiver avr-891
Bummer.
Dec 26, 2010 | Bose 901 VI Main / Stereo Speaker
No picture with cable to denon AVR-589
Long and painful answer!!! However, in the end, you need to bypass HDMI thru your receiver and go direct to the TV. Connect Digital Coaxial or Optical for audio to your receiver. Your version of HDMI in your receiver is not compatable with today's HDMI version. Yours is 1.1a and the current version is 1.3b going to 1.4. If you want detailed info as to "why", just google "HDMI 1.1 problems" you can read for hours! Sorry for the bad news! However, it is what it is. Hope this helps. If you need further help with setup, post a comment and I can give you further help.
Feb 28, 2010 | Denon AVR-589 Receiver
How Do I Connect My Dell Laptop to a Demon AV Receiver
use a 1/8in stereo to two male RCA plug to connect from your computer headphone out to an input on the Denon such as AUX or CD
Jan 25, 2009 | Denon AVR-587
Back speakers with av denon 1908
Plug your rear 5.1 speakers into the surround speaker connections. Be sure to use the AVR 1908 set up menu to set rear speakers (not an amp assign). Hope this helps.
Jan 03, 2009 | Denon AVR-1908
335 people viewed this question
 Grubhead
Grubhead
