Question about Garden
Idle screw adjustment
Tune up procedure
  • 7,482 Answers
Hi deweyvr...
I think this i what your looking for.
If you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 23, 2013
Hero Duet air-fuel adjustment
Hi, Sakaresrini it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
1. The mixture screw may be sealed at the factory with a Welch Plug please review the following video for removal.
https://www.youtube.com/watch?v=wAXcksgvDkM
2. The mixture screw manages a range of 3 complete 360-degree counterclockwise turns from the bottom/closed position.
3. The mixture screw should have a spring and o-ring for tension and sealing integrity.
4. Turn the mixture screw clockwise until it gently bottoms out, this makes the fuel charge very lean and the engine should not idle if it does then the pilot/idle jet is too big and needs to be replaced with the next size smaller.
5. Turn the mixture screw 1 and 1/2 turns counterclockwise to establish a baseline for starting the engine.
6. To fine-tune the idle circuit, adjust the mixture screw 1/4 turn in or out to achieve maximum idle RPM, wait 15 seconds between each adjustment for the idle to settle.
7. Never go past 3 full turns out this will make the fuel charge rich, foul plugs, and produce black smoke out of the exhaust, if the engine RPM keeps increasing past 3 turns the pilot/idle jet is too small and needs to be replaced with the next size larger.
8. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
9. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to adjust and tune carburetor of Hero motorcycles
How to tune your carb properly Team BHP
Hero Motocorp Duet 110 User Manual
Shop At Hero Motocorp Duet Scooter Parts And Accessories Online Store...
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Apr 09, 2018 | Hero Motorcycles
Tip
How to adjust carb settings
Hi Charlie.<br />Operations to be performed depends on how much tuning is needed.<br />Carb setting regulates the ratio between air and fuel in the mixture aspired into the cylinders.Optimal air/fuel ratio is usually around 14(air) to 1(fuel). I illustrated the complete job with cleanup and jet replacement and adjustment. In some situation you do not need to perform complete tuning, which involves taking apart the carburetor. In that case perform basic regulation setup using the two adjustment screws at one side of the carb. Adjustment simple procedure starts from part 2/Adjustment. A good approach is first doing adjustment using idle and thickener screws. Then do the whole tune up if the simple adjustment does not work.<br />The complete tuning is based on carburettor cleanup, regulation of main jet and idle jet and needle setup.<br /><br />Part 1 : Complete tuning and cleanup:<br />1. Take apart the carburettor,<br />2. Undo the float chamber(6 in diag) held by screws (26 in diag).<br />3. Clean bowl with with carb cleaner (put a lot of it in the bow, wait a bit and dispose it-finish the job with a cloth if needed) . Clean floats (nr.4) and other parts using carb cleaner and cloth.<br />4. Use a flat screwdriver to remove the main jet screw (placed in the chamber, held by big golden screw, goes between the floats). Spray the main jet. You must be able to see through it.<br />5. Use the carb cleaner to clean the accelerating pump and all the other parts inside the part. Needle and small parts must be cleaned. Clean the idle jet, which is the smaller golden screws. If you have a compressor blow into the jets (you can blow them even without compressor, but follow H&S).<br />6. If possible replace main and idle jets. Sometimes you may like to replace the jet with a bigger one to get a richer mixture.<br />7. Adjust the needle if needed. A lower needle settings means a richer mixture.<br />8. Remove idle adjustment screw (7) and main adjustment screw(31), clean them screw them back in without tightening and perform part 2. Leave the screws about one and half turn from all way in.<br /><br />Part 2: Tuning and minor cleanup - Here you mainly operate on idle and air (thickener) adjustment screws (8 and 12 in diag)- Start from here, if this does not work, do part one:<br /><br />1) If the engine runs start from idle adjustment: screw or unscrew the idle regulator to adjust the idle speed, the screw is placed to one side of the carburetor and has a spring (part 12).<br />Keep idle least slightly higher than the minimum needed. Example, if the engine stays on slightly below 1000 rpm, set idle to a bit higher with engine revving above 1000 rpm.<br /><br />2) The thickener, placed near that of the minimum screw regulates the air flow. Tighten the screw and unscrew 2 turns from all the way in. Do regulation from this position. <br /><br />Here carburetor diagram and part list. The diagram is taken from service manual. The manual for Lifan 150 (does not include carb setting) has been uploaded here:<br /><br />http://www.mediafire.com/?o3r8x2ujrdbfb6o
on Oct 29, 2011 | 2008 Lifan Delta 250 V Twin
2003 Bajaj Wind 125 idle adjustment
Hi, Suresh it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
How to diagnose carburetor vacuum leaks on your motorcycle basic carburettor adjustment tuning 4 stroke and how it works http://mototh.com/files/kawasaki/Boss_175/Kawasaki-Eliminator-125-Service-Manual.pdf
Kawasaki BR 125 WIND 125 B2 B2 2005 Parts
Manual Kawasaki Bajaj Wind 125
Mar 14, 2018 | 2005 Bajaj Wind 125
Suzuki Raider J 110 air-fuel mixture adjustment
Hi, Ed it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
Carburetor Know How and What and Tuning
Idle mixture adjustment air or fuel screw adjustment
Suzuki Raider Pro 110 2013 service manual DOWNLOAD FREE FULLMANUALS COM
http://mototh.com/files/suzuki/Smash/9900B-45H10-000-Smash-110.pdf
http://mybikemanuals.com/suzuki
Sep 02, 2017 | Suzuki Motorcycles
How to adjust carb on Honda fmx 650
Hi, Hachem it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Thread FMX 650 Tuning
Officine08 it Passione Motociclistica Carburetor tuning kit Honda FMX 650...
https://nrazalqwf.files.wordpress.com/2015/08/service-manual-honda-fmx-650-pdf.pdf
http://www.partsfish.com/page/oem-parts-for-honda
2006 Honda FMX650 Manual del propietario in Spanish
Jul 02, 2014 | 2005 Honda FMX 650
Honda Dio carb air screw settings
Hi, Anonymous it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
50cc GET Carburetor Basic Tuning
Honda SK50M Dio Service Manual
http://www.hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/SK50M-1992.pdf
Aug 02, 2013 | Honda Dio Motorcycles
2002 Honda CR 125 R fuel mixture adjustment@
Cr125 carb adjustment for noob
2 stroke Carb Tuning Idle Adjustment Fix Your Dirt Bike com
Honda CR 125R 2002 Sevice Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CR125R 2006 Owner Manual
Jan 19, 2013 | 2002 Honda CR 125 R
2003 Honda CRF 150 F carburetor adjustment@
How to tune CRF150F dirt bike other basics
How To Carburetor Idle Pilot Screw Adjustment Honda XR70
CRF150F service manual repair 2003 2013 CRF150 Download Manuals Technical $15
Honda 2004 CRF150F Owner Manual
Sep 11, 2012 | 2003 Honda CRF 150 F
1994 Kawasaki KX 250 how to adjust the carburetor
Hi, Danny it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
Adjusting the air screw
Carburator Theory and Tuning
https://www.scribd.com/doc/121008272/KX125-KX250-94-98-Service-Manual
OEM Parts for Kawasaki
1994 Kawasaki KX250 Owner Manual
Sep 24, 2011 | kawasaki Motorcycles
2003 Yamaha TW 125 A/F mixture adjustment
Hi, Revasns2001 it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
7. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
8. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
Life On 2 Wheels
CV carburetor tuning part 2 Mixture screw adjustment
Yamaha TW125 1999 Service Manual
OEM parts for Yamaha
YAMAHA TW125 Owner Manual
Aug 23, 2010 | 2003 Yamaha TW 125
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
