Question about HP LaserJet 4 plus Printer
Print out from the pc
I am getting on the little screen on the lazerjet 4 plus printer MP load paper and the printer has papers so what do I have to do i do not have the catalog for the printer on what site can I read the catalog too.
thank you
    Genius:
  • 2,120 Answers
Pull down the front door of the printer and load paper there MP = multi-purpose
www.hp.com
Posted on Mar 12, 2009
How to fix PC Load A4 printer problem
A4 refers to a paper size, so its asking for that size of paper to be loaded.
Mar 15, 2015 | HP LaserJet 4 plus Printer
Canon load correct paper
•When copying or printing received faxes, check the following:
1. Paper loaded in the machine
2. The paper size specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
•When printing from a computer, check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Oct 15, 2013 | Office Equipment & Supplies
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the paper in the paper cassette or multipurpose tray is different from that of the paper specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>. You need to load the correct size paper or change the paper size in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 16, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
Message window shows "load mp
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray).
If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
Jun 15, 2011 | Lexmark T634 Laser Printer
Paper from Tray doesn't load.
put paper in the upper slot (known as the MP), pull all paper from lower tray, send document to print and see if it prints ok - if it does, the problem may be with the lower print drawer - there is a spring under metal pad that lifts paper so it's grabbed by the printer paper transport. the spring may have broken or become dislodged so separation pad (the metal plate holding paper up) remains down - the transport "thinks" there is no paper
Jul 08, 2010 | Brother MFC-8460N Laser Printer
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Jan 14, 2010 | Brother MFC-9440CN Laser Printer
Lasejet 4 plus- try to print. lower paper cassete full. printer screen says pc load letter and have to manualy load paper. print icon on computer says out of paper
There is a paper empty flag sensor, looks like a plastic paddle, in the tray area. Pull out the paper tray and flick it; make sure that it is not jammed.
Also on the right hand side there is a paper pick- up roller, clean it with a cloth with some alcohol. See page 4-13 for the location of paper feed pick-up roller. page 5-27 shows the paper empty sensor flag
Here is the service manual:
http://home.comcast.net/~wannabeyote/hp-lj-4-5-m-n-plus.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | HP LaserJet 4 plus Printer
Tray selection issue: Documents may be setup to print to the MP feeder, (multipurpose feed, not manual feed), but the printer will only pull from tray 4. I'm not sure why, earlier this week it would o
The usual reason that the printer will ask you to load paper into the MPF is that the green paper guides in the paper tray is not clicked in the right position. It only needs to be slightly out of position to give the wrong paper size info to the printer. The easiest way to confirm if the guides are correct is to print the Menu Settings Page. Check that the paper sizes listed in that report are the same as the actual paper sizes in each tray. If it's different you need to adjust the guide correctly. It's remotely possible that the sensing switch is faulty but it's more likely that the paper tray guide isn't latched in it's correct position.
May 29, 2009 | IBM Infoprint 1532 Laser Printer
I HAVE LASERJET 4 PLUS. WHEN I GIVE JOB FOR PRINTING THE PRINTER DISPLAYS A MESSAGE AS PC LOAD LEGAL. PLS HELP ME IN SOLVING THE PROBLEM
The document you're trying to print is formatted for legal size paper, and the tray contains only letter size. if it's a legal size, put legal paper into the MP tray, or override the setting and manually select "letter size" in the printer dialog box.
Apr 04, 2009 | HP LaserJet 4 plus Printer
Hp laserjet4 printer will not print labels or envelopes
MP LOAD,
PC LOAD, or
LC LOAD
paper size,or
envelope size
The printer received a request for a paper or
envelope size not available in the printer.
MP LOAD: Load MP Tray with the requested
media. If the size is not selected in the printer
control panel, use the [MP[Paper[Size] key to enter
the requested size, or press [Shift] + [Continue] to
draw the requested size from another source, if
available.
Note: If MP LOAD remains in the display, you may
have to clear the buffer by resetting the printer.
Press [Shift] + [Reset].
Feb 12, 2009 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
